S 475 Info
Old May 13, 2010 | 09:12 PM
Farmboy 2.0's Avatar
Default S 475 Info
Just wondering about s 475's anything and everything!! Thanks
Old May 14, 2010 | 04:56 PM
turbo20psi's Avatar
Here are the specs of it.
Turbocharger Name - S475
Compressor Wheel Inducer - 75mm
Turbine Wheel Inducer - 96
Turbine Wheel Trim - 96
Turbine Wheel Part # - 410100-3
Turbine Option - Outlet - V-Band
Turbine Option - Inlet - T6
Turbine Option - A/R - 1.32
Horsepower Rating - 600-1000
That turbo is used in twin set ups mostly.But if your going to use it as a single your going to have to change the cam in the truck.You will be looking at next year before it lites with the stock cam.She like's high RPMs as a single.O-ringing or better yet fire ringing is a must along with studs.
Old May 14, 2010 | 10:51 PM
Its going in my twin setup i just got under my 62
Old May 19, 2010 | 10:57 PM
jkidd's Avatar
Its a great setup with 62/ s475 It will support about 700-750HP, slightly larger than the BDr700 set up. get 200+ hp injectors and make sure you have your head taken care of.
Dfro22
Aug 12, 2015 06:07 AM
Jet A Fuel
Aug 3, 2015 10:45 AM
klein444
Feb 27, 2015 01:53 PM
Dec 3, 2014 08:10 AM
760DAN
Oct 31, 2014 12:53 PM
