fuel pressure sender
Old May 13, 2010 | 02:57 PM
89silverbullet's Avatar
Default fuel pressure sender
where is the best place to put the sender on? if any one has pics it would be appreciated.
Old May 16, 2010 | 11:33 AM
jshaw214's Avatar
I'll see if I have one on photobucket if not send me your email and I'll send it to you from my phone.
Old May 16, 2010 | 02:48 PM
Outlet of the fuel filter housing or on the test port on the VP-44
Old May 16, 2010 | 05:58 PM
Evil, is it the one next to the banjo bolted fuel line towards the left tire. I think it is male so I will need to get a female/female adaptor. Right? Pics would still be supa cool to see jshaw if you could get them. I thought that these kits came with all fittings
Old May 16, 2010 | 08:28 PM
I personally do not like using the test port - I like to use it for what it was designed for - a TEST port. Of course, becaouse your using an electric guage - your install will be a little bit different. Instead of having the hose - you would screw your sender into either location.
Old May 18, 2010 | 01:24 AM
Super huge thanks evil!
Old May 18, 2010 | 01:31 AM
01quadcab's Avatar
you can get the needle valve at a hardware store that has a 90 built in male and female ends. I just got one for my setup.
Old May 18, 2010 | 11:06 AM
jshaw214's Avatar
Mine is connected to the vp. Just make sure your sending unit is vertical. I strapped mine to the brake boost lines.
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
