3 speed no overdrive
Old May 11, 2010 | 10:08 PM
HAYMAFIA's Avatar
Default 3 speed no overdrive
i have a 91 with an auto without overdrive. are these trannies pretty stout? my plans are to put a 3 speed brownlipe behind it 20%under, direct, 20%over. and already installed the 4.10 dually rearend. is the tranny going to hold up to a lot of pulling and if not what do i need to do to it to tote the load. i regularly haul 10 tons not counting trailer.
Old May 11, 2010 | 11:54 PM
tltruckparts's Avatar
IMO i dont think these trannys are very stout at all. i believe a non OD is stronger as the OD unit is a weak link. but the torque converter and valve body are the notorious weak links. but if your hauling 10 tons regularly i wouldnt trust the 727 but thats just MY opinion.
Old May 12, 2010 | 08:09 AM
HAYMAFIA's Avatar
im planning an nv4500 swap but idk when i'll have the time. i have anv4500 chevy tranny. do you know what itd take to put it in the dodge
Old May 12, 2010 | 10:18 AM
alot. new hydraulics, adapter plate, starter. clutch hydraulics, clutch etc. unless you pay the bucks for one of the adapter bellhousings
Old May 12, 2010 | 07:00 PM
HAYMAFIA's Avatar
i have the hdraulics, starter, bell housing, and clutch. will the nv4500 bolt up to the first gen adapter plate. if not i have a 2nd gen. adapter plate
Old May 12, 2010 | 10:36 PM
if its a chevy bellhousing then no it wont work. if its an nv4500 dodge bellhousing youll need a 2nd gen adapter plate
Old May 13, 2010 | 04:15 AM
RSWORDS's Avatar
Hauling 10 tons regular I would not truck any light truck tranny for very long.
With a few modifications the 727 in the 1st gens is a VERY stout tranny as far as autos go. The converter is alot better then the 518 converter but still could use a upgrade.
Old May 14, 2010 | 12:27 AM
HAYMAFIA's Avatar
i have a dodge bell housing. idk. i prolly start gathering what i need and when i trash the auto, i'll swap in the nv4500.
Dertyd
24
Jun 7, 2015 02:45 PM
May 17, 2015 12:10 PM
FF131
9
Mar 26, 2015 07:06 AM
thetrot
Jan 15, 2015 09:51 PM
Canadiancummins93
8
Dec 10, 2014 09:03 PM
