what is this part?
Old May 11, 2010 | 09:24 PM
kieron_kohlmann's Avatar
Default what is this part?
what is the name of the part that connects the pitman arm to the top of the spindle? is a little shaft?
Old May 11, 2010 | 10:47 PM
redwood logger's Avatar
i could be wrong but it sounds like you are talking about the idler arm, and i have read some where that you can replace it with a adjustable one off a chevy. I thoght about doing that to try to correct my **** poor right hand turning issue, but i think i need to brace the steering box as well to fix it.
Old May 11, 2010 | 11:35 PM
tltruckparts's Avatar
no its not an idler arm these are straight axle trucks they dont even use idler arms. from the pitman arm to the knuckle (it sounds like thats what you mean when you say spindle) would be the drag link. its what turns the knuckle when your pitman arm turns. should be about a foot long or so with a tie rod end on each side. sound about right?
Old May 11, 2010 | 11:45 PM
Begle1's Avatar
Two wheel drive or a four wheel drive?
On a two wheel drive the Pitman arm connects the steering box to the center link, the center link connects to the idler arm and both tie rod ends, the idler arm mounts to the frame, each tie rod end connects to another another tie rod end with a sleeve, and those tie rod ends connect to the steering knuckles.
Old May 11, 2010 | 11:49 PM
hes got a 4wd i dont why i remember that but im pretty sure he does.
and yes they do use a idler arm on a 2wd i didnt even think about that i just already knew he had a 4wd for some reason.
Bslamb
Jeep Liberty
Aug 10, 2015 04:28 PM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
Mar 4, 2015 08:20 AM
jrsavoie
Feb 6, 2015 09:44 PM
countryboy040993
10
Nov 16, 2014 08:21 PM
