Radiator removal
Old May 11, 2010 | 05:52 PM
Billy D's Avatar
Default Radiator removal
Well I thought I could pull it, just movin the fan shroud. WRONG! What do I gots to take off to get the radiator out.? Should I replace the heater core as well? It's OE...
Goldie still hes the factory Chrysler radiator cap, ha
Old May 11, 2010 | 07:24 PM
DirtyDozen's Avatar
on a 90, after the fan shroud and hoses are off, you just pull the 4 little bolts that hold it to the rad support and it should come right out, at the most, there might be a rubber cowling over the top of it thats held on with plastic clip-type things
Old May 11, 2010 | 08:19 PM
tltruckparts's Avatar
exactly. 4 bolts two on each side they run vertical on the outsides. pull those 4 and the hoses and you should be good
Old May 11, 2010 | 08:30 PM
Billy D's Avatar
There was a little freakin L-bracket that was holdn me up on the bottom of the radiator. I was about 1 step away from getn the BFH. Guess heater cores next, nuthn else left
Old May 11, 2010 | 08:32 PM
have fun with the heater core
Old May 12, 2010 | 12:23 AM
big bad diesel 416's Avatar
Site Sponsor
X2
Old May 12, 2010 | 04:24 PM
Billy D's Avatar
Is the HC a bit@h?? I've had no problems with it, just new radiator, T-stat, hoses, why not a HC.
Old May 13, 2010 | 11:39 PM
Site Sponsor
dose the terms "what can go wrong will" and "if it aint broke dont fix it" also " i fixed the heater core and now the truck wont start because its a dodge" mean anything to you?
seriously man i would just let it be
Old May 14, 2010 | 12:06 AM
god if that aint the truth i dont know what is
Old May 15, 2010 | 09:43 PM
Billy D's Avatar
I guess that's a negitive
