need help with 6.0
Old May 11, 2010 | 08:04 AM
retiring's Avatar
Default need help with 6.0
My 6.0 has multiple sympyoms hesitates when taking off from stop if setting very long at idle and blows out black smoke when I excelerate and then runs fine. Also lacks power until warmed up acts like turbo not spinning up.
Old May 11, 2010 | 08:34 AM
Diesel Powered Rocket's Avatar
The vanes are stuck in your variable vane turbo or the control wire is unplugged from the turbo VGT control valve but you may have Faulty EP sensor, VGT control valve slow to respond, Stuck VGT valve, faulty PCM.
Old May 11, 2010 | 10:46 AM
Mdub707's Avatar
How many miles are on the truck, how often does it get used, and what is it primarily used for?
Sounds like stuck turbo vanes to me. There is a cleaning procedure you can do yourself.
Diesel Technician Society
Old May 11, 2010 | 04:06 PM
retiring's Avatar
Thanks for response. New to diesel repair know just a little. I drive 3 to 4 times week mainly used for towing 5th wheel. How do you clean the vanes?
Old May 11, 2010 | 04:14 PM
Mdub707's Avatar
Click on the link I posted in my last response that says "Diesel Technician Society" it tells you in detail how to do it....
Old May 11, 2010 | 04:57 PM
retiring's Avatar
Ok thanks I found that I have 78000
Old May 11, 2010 | 11:15 PM
Mdub707's Avatar
It takes some time to do, but cleaning the turbo certainly wont hurt anything, wont cost nearly anything and is a good way to eliminate possibilities.
Old May 12, 2010 | 06:28 AM
retiring's Avatar
Thanks Mdub707 I've been reading ur DTS and it's been real helpful will buy neccessary parts today.
Old May 12, 2010 | 09:46 AM
Mdub707's Avatar
Let us know how you make out with it.
Old May 12, 2010 | 11:07 AM
Lange503's Avatar
also mine did that too and it was the injection control pressure module that was doin it, took off from a stop light in Salt Lake and just clouded the entire intersection, needless to say people werent happy ha
