Hot unlock for Edge.
Old May 10, 2010 | 10:58 PM
tdub's Avatar
Default Hot unlock for Edge.
Im thinking about getting the hot unlock code for the edge with attitude. Im not planning on running level six constanly, but just to have it for a few minuates on the fly. Any suggestions, warnings, or advice for me?
Old May 10, 2010 | 11:21 PM
Just take it easy on your stock clutch.
Old May 11, 2010 | 09:42 AM
dieseldude03's Avatar
Like he said. Your stock clutch won't like you. Also make sure you set the Max Boost setting to something like 38psi and keep an eye on EGT's. The HOT unlock will dump enough fuel to take the stock turbo to around 45psi, which is more than enough to make it go BANG! While 45psi sounds good, anything over 32 or so with the stocker is just going to be hot air that won't make any real power anyway.
BTW, unless Edge has changed something recently, the "HOT" upgrade doesn't add a level "6" on the 03-04 trucks like it does with the 04.5 and above models. It just re-calibrates all the levels, with number 5 being the full-on HOT setting. I usually keep mine set on level "3". After getting the HOT unlock, level 3 felt closer to level 4 and level 5 got right with the program!
Old May 11, 2010 | 05:14 PM
tdub's Avatar
i have a Voltair after market preformance clutch with brass springs.. think that will do? and i have the EDJ...... model where you have to mail it in for them to rewire everything. it isnt the "in monitor" model where you just enter the 4 digits.
Old May 11, 2010 | 05:55 PM
I would think would be fine with that clutch. You have the same model Juice that I do. When you get it back, the silver sticker on the end will read EDJ-3000 HOT, along with a new version number.
Old May 11, 2010 | 06:53 PM
tdub's Avatar
What all improvements did you see?
j1004ss
9
Dec 23, 2021 02:59 PM
camp9
Mar 25, 2017 07:40 AM
drsparkman
Nov 4, 2015 10:32 AM
98suburbandiesel6.5l
Jul 25, 2015 03:25 PM
Dustin M
Mar 17, 2015 08:59 PM
