This Is Not Good ! (Cummins Edition)
Old Sep 19, 2007 | 09:56 PM
DB Admin's Avatar
Banned
Default This Is Not Good ! (Cummins Edition)
A Computation Thread of Tall Tale Signs thats This is going to Cost me Some Money !
Tell us what happened before it broke ...
Ill Start ...
ECM Grenaded
Engine Temperature Gauge Pegged and truck defueled Over and Over ,till i got home Barely No CEL !
VP44 Punted
Real Hot day Comp 5x5 Running the **** out of it for 45 mins , Was fueling it up and it fell on its nose , Went in to Limp Mode and Got me home seen P0216 and whiped the tears from my eyes
Windshield Wiper Motor Junked its Self
They Started Working by there selves and not working when i wanted them to
:pc:
Old Sep 19, 2007 | 10:06 PM
Uncle Bubba's Avatar
The most prominent symptoms I have been through.
VP44 shot craps: Lack of power only noticable when I was pulling, fuel mileage dropped sharply, and eventually it wouldn't start when the truck was warmed up with out pouring cold water over the pump then it would fire right up.
Clutch slave cylinder: Truck wouldn't disengage the gears, so when you push the clutch in it still had some forward pull all the time. I could change gears but had to hold the truck in place with the brakes to stop.
APPS Out Of Whack: Loss of power, intermitent dead pedal on rare occasions and fuel mileage dropped off some.
Front Wheel Bearing shot: Truck had a constant pull to the bad side that got worse while breaking and the hub got hot enough to burn skin after only a few miles of driving.
Old Sep 19, 2007 | 10:32 PM
Lostnwalmart's Avatar
Driveing down the high way and all of a sudden the truck is slowing down and not accelerating and you hear a very loud grinding noise...... Clutch # 4
Old Sep 20, 2007 | 12:05 AM
toy4xchris's Avatar
merging onto the highway and I heard a snap the truck lost all power died and rolled to the side of the road.... cam retainer broke cam walked out smashed cam gear, ps pump gear, timing gear housing, bent 2 push rods. I havent even though to add up the receipts
Old Sep 20, 2007 | 12:26 AM
Thats a GOOD one...ouch...
Old Sep 20, 2007 | 08:10 AM
Whit's Avatar
Site Mascot
OEM HX35 gernaded.......to many rpm cuz I had a turnbuckle on the wastegate
Old Sep 20, 2007 | 09:43 AM
Wyatt Earp's Avatar
VP44 packed it in. 2 Lift Pumps, Power Steering Pump, Death Wobble and that's about it.
No major events surrounding these issues though. Not like a blazer i had that went from 80 mpg to 0 in about 150 feet! pre-air bag days, marks from steering wheel on ribs. Ouch. I split the drive line because the trans was out of fluid due to a crack in the bell housing.
Old Sep 20, 2007 | 09:59 PM
toy4xchris's Avatar
yea I guess it was one heck of a learning experience.
Old Sep 23, 2007 | 03:51 PM
EMD567's Avatar
Driving home one night I started hearing a clunking noise every time I hit a bump or a spot in the road. Most people would just assume "well I need new ball joints." Too bad I had just done them. Got home and jacked the truck up the next morning expecting tie rod ends or a drag link or something, ended up the lower control arm rotted right off the front axle on the drivers side. That was an expensive fix. You cannot buy new axle mount pads from Mopar, Dana, or any auto parts store. I called everywhere looking for new axle mounts. No dice. "give: Ended up buying a junkyard axle plus a lift kit while the front end was out. The truck really ended up needing new control arms, springs, steering stabilizer, ball joints (on the new axle) and hub/bearing assemblies.
I lost atleast 3 throttle retun springs before breaking down and going to Mopar to buy new ones. That wasn't expensive, it was just a nusance. Truck wouldn't idle down, throttle was excessivly touchy.
Old Sep 27, 2007 | 01:57 PM
Super Dave's Avatar
The worst thing that has happened to my truck thus far was when I took it to one of those DIY car washes (its a dually) and washed it all up nice and purty. Then I drove directly to Flying J to air dry the truck at high speed and filled it up.
When I started it back up the CEL came on and my heart sank. I had my laptop with me with the electronic service manual--so I did the key on trick and it threw a code. I don't remember the number, but it was something like "ambient temp sensor/intake temp senser disagree".
Well I figured that couldn't be very important, so I drove it home with the CEL on. When I got home I cleared the code with my scan tool and unplugged the temp sensor in front of the intercooler looking for water in the connector. Finding none, I plugged it back in and let the truck sit thinking that maybe when I washed it, the temp sensor didn't like getting wet. I let it sit for a few hours and when I went back out and started it back up - no CEL and no more codes. It's been fine ever since
