1999 cumins oil pressure
Old May 9, 2010 | 11:23 PM
countryboy4450's Avatar
Default 1999 cumins oil pressure
i have a 99 cummins and the oil presure gauge is very weird it comes on some times others it doesnt but theres new clean oil in it i just not sure if its the sensor or a sending unit what do you think? thank you
Old May 9, 2010 | 11:28 PM
CSIPSD's Avatar
I moved your thread into the Cummins section... Might get more exposure here.
I dont know a ton about the Cummins motors, but I would bet its a sender issue...
Old May 9, 2010 | 11:50 PM
Change the pressure sender out and all will be good again.
Old May 10, 2010 | 07:37 AM
Okay ill look into that thank you
Where is the sending unit and sensor if you know thanks
Last edited by countryboy4450; May 10, 2010 at 07:37 AM. Reason: Automerged Doublepost
Old May 10, 2010 | 08:39 AM
turbo20psi's Avatar
24 Valve Fuel System Components It is number 22 on the diagram.You can get the part from cummins.
Old May 11, 2010 | 01:52 AM
Ed ke6bnl's Avatar
Mine did that and it was the oil pressure sending unit. You need to get it from cummins not Dodge about $70 Dodge $250 or so. and if you do a search you can get the same replacement not a supstituted that needs additional computer flashing. $20 + $200 flash.
the part is from a TDR quote and it worked fine without a Dodge computer flash for Me ED
Offline
Old Reader's Rigs Gallery
For those of you who have been following this thread or may be finding this on a search, I want to confirm that the oil pressure sending unit is available direct from Cummins under the part # 4921511 as mentioned in a previous post. At least in my 2001, it is a direct replacement and does not require a reflash or any adaptation to work correctly. I did this replacement last evening in my truck and it works perfectly.
Here is a photo of the packaging.
Old Sep 20, 2012 | 12:10 AM
alittle5150's Avatar
Default wait to start light
today i noticed my wait to start light isn't working ... i'm new to the cummins family .. i don't know what to check .... any advice would be appreciated.... thank you so much !!! Richard
Old Sep 20, 2012 | 12:40 PM
dieseldude848's Avatar
bought one from these guys about a year ago. havent had any problems since, and its a genuine cummins part.
'98.5-'02 Dodge Turbo Diesel Oil Pressure Sensor-Geno's Garage
Old Sep 20, 2012 | 08:48 PM
BLACKSHEEP757's Avatar
this is the wrong spot for this question for sure (HOPEFULLY A MOD WILL MOVE IT) but,now that its been mentioned it makes me realize ive never seen 1 on mine either........ any suggestions guys?.....does this mean my glow plugs aren't firing? I just bought this truck in may and the temp has always been warm here so far but my truck fires right up every time without hesitation but cooler weather is on the way
Old Sep 29, 2012 | 09:58 PM
kerley's Avatar
Default oil pressure
I had the same problem with my oil pressure so I bought a new sending unit from Cummins for $67.00. When we tried to install we had the wrong sending unit. We cleaned the old sending unit connector and wire, Bingo all works well. I just returned the new sending unit to Cummins. Good luck.
