Tapping the pump
Old May 9, 2010 | 10:55 AM
Brandon J's Avatar
Default Tapping the pump
What do yall mean by tapping the pump and how is it done. Also what do you gain by doing it?
Old May 9, 2010 | 11:14 AM
00' Quad Cab's Avatar
Tapping the pump usually refers to the installation of a tuning box with a pump wire.
When you tap the pump wire with the box it gives fueling control to the tuner.
Old May 13, 2010 | 09:50 PM
Brandon J's Avatar
How is it done?
Old May 13, 2010 | 09:52 PM
a scotchlok connector usually. Which is not the best way. The best way to do it is with a stealth plate cover or with good old solder and heatshrink.
Old May 13, 2010 | 10:07 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
stealth plate is the best way
Old May 13, 2010 | 10:09 PM
Farmboy 2.0's Avatar
Stealh plate for sure. I shoulda went that route looking back so much nicer
Old May 13, 2010 | 10:18 PM
Brandon J's Avatar
thanks guys does it make a big difrence when you tap the pump.
Old May 13, 2010 | 10:22 PM
oh yes it does make a big difference.
But befre you do this - make sure you have proper guages - including a fuel pressure guage and a better lift pump. Tapping the wire on an otherwise stock truck usually results in a dead VP-44.
What are the mods that youve done to your truck?
Old May 13, 2010 | 10:29 PM
Brandon J's Avatar
I have an afe stage 1, banks otto mind and 4 inch straight piped.
Old May 14, 2010 | 07:17 AM
RAW's Avatar
RAW
https://www.dieselbombers.com/5-9l-2...e-install.html
