lift kit
Old May 9, 2010 | 10:43 AM
93smoker's Avatar
Default lift kit
Hay
This is just a thought. I am trying to find a cheep way to lift my truck. All the lift kits under600.00 are for 1/2 ton trucks! If I had a 1/2 ton and used a snow plow those springs would have more weight then mine do now with the Cummins?!?!? If I am not going to use a plow or anything (just clear tires) can't I use a 1/2 ton lift on my 3/4 Cummins? Why or Why not. thanks
Old May 9, 2010 | 12:23 PM
NadirPoint's Avatar
Springs are designed to carry a certain load. !/2 to springs are not designed to carry 3/4 ton load.
Old May 9, 2010 | 01:36 PM
tltruckparts's Avatar
x2. do it right and safe. that way you dont kill yourself or someone else on the road when a spring gives
Old May 9, 2010 | 11:56 PM
pewder's Avatar
Bad things happen when ya do things cheep and incorrect. You can just ask this guy if you should go cheep.
https://www.dieselbombers.com/off-ro...ugly-side.html
Apr 29, 2015 08:20 AM
slowstroke
For Sale
Mar 27, 2015 05:19 PM
Ruddedawg5.9
Feb 22, 2015 10:54 PM
turbodiesel123
Oct 24, 2014 10:27 PM
JJ Diesel
Oct 6, 2014 11:21 PM
