Afc
Old May 8, 2010 | 11:21 AM
BRE's Avatar
BRE
Default Afc
Ok i have a question. If i tune the afc of the truck for full throttle and set it with an air line hooked up at say 35lbs with out a fuel plate it will pop the waste gate at 35lbs right? I have in the past done away with the whole mess, plate, afc and everything. im tryin somethin new so i wanted to make sure i understood.
Old May 8, 2010 | 11:26 AM
12vcummins96's Avatar
no the afc controls fuel only it will not make the wastegate hold longer get a boost elbow for that
Old May 8, 2010 | 11:36 AM
BRE's Avatar
BRE
I thought i miss understood... thanks! Im still a little confused on tuning the afc off the truck. i have read the right ups and all but for some reason i still wont click.
Old May 8, 2010 | 06:04 PM
85_305's Avatar
Being Evaluated
Dont remove the afc. Just dont do it. It's very very tough to drive w/out it. It's smokey and sucks fuel and can be very slow if you dont know what you are doing.
Get a 100plate, put it full forward, and put the afc full forward.
Old May 8, 2010 | 09:41 PM
Hammer's Avatar
SOMEDAY,someone will expalin to me why everyone thinks a 100 plate is the best for all pumps.
NO!
It will hold the rack and not allow for full travel until 35psi.
BTW...85 305...
You should do a little more studying on your P-Pump CPL's and what works for each one.If you would do that then you would understand that there is no one plate that works for all of the P-7100's,unless your running a 0 or plateless.
Old May 9, 2010 | 10:30 AM
85_305's Avatar
Being Evaluated
Ya I should have told him to research instead; I know my 100plate works for my 215 pump. But thats about the extent of it.
Old May 9, 2010 | 02:57 PM
cumminspwr11's Avatar
there is a very good write up on a the p pump and afc mods and funcutions with a great pic of it all. i tired getting it posted here but had no luck, google search, 12 valve afc mods-new england turbo diesel. if that doesnt make it click idk what will
Old May 12, 2010 | 08:07 AM
BRE's Avatar
BRE
Alright... anyone have any tips for tuning the afc with no plate?
Old May 12, 2010 | 09:09 AM
94 12valve's Avatar
yep, adjust the gov arm so it is all the way up, mod the barrel, leave the foot alone,slide the housing back, and set your spring pressure with shop air.
Old May 12, 2010 | 03:42 PM
daveO's Avatar
So, I know there's no "one size fits all" pressure for setting the springs, but what's a good ballpark to start from?
