93 cummins swap in to a 93 1ton chevy
Old May 8, 2010 | 10:10 AM
JDcummins's Avatar
Question 93 cummins swap in to a 93 1ton chevy
ok guys im getting a 93 1 ton single cab dually for my wife and its got a cummins in it but it was a ranch truck and I havent gone to see it yet but for 200 bucks ill pic it up so my question is who done a cummins in a chevy an how did you get the gauges to work or what or how did you get every thing hooked up please im getting his truck next week and I need info thank in advance JD
Old May 8, 2010 | 10:53 AM
tltruckparts's Avatar
its ALOT of work. all of my stock gauges work but i added a mechanical water temp just for extra measure. i used a chevy alternator, which makes the voltage and tachometer work. i used the stock chevy oil pressure and water temp and just found adapters to fit them into the factory dodge locations. and speedometer is very tricky if you didnt use the chevy transmission. if you used a dodge transmission in it you just need to take it to a speedometer shop there is a special converter they will need to use for it
Old May 9, 2010 | 05:20 AM
Bill H's Avatar
iI put a 90 cummins in my 89 Chev 1 ton...went in nice....built a 3" lift kit for the cab
also used delcoramie alenator....used adapters and used Chev sendouts...i usde Dodge trany and transfer...had new drive lines built..the Chev speed O cable worked in the Dodge transmission but is a few mph off...you can get the coverters at transmission shop as tltruckparts said...it runs like a dream...my 1ton Chev rides smoother then the Dodge 3/4 ton the diesel came out of
Old May 9, 2010 | 10:30 AM
that is a whole different monster though. putting the engine in an older eighties body chevy truck is ALOT easier than doing it to the 90's style trucks.
but if everything is already done but wiring the gauges you should be set.
Old May 9, 2010 | 10:32 AM
JDcummins's Avatar
Thanks guys yall got any pics of them and more info
DieselDan370
Diesel Engine Conversions
Aug 23, 2016 02:24 PM
STDiesel59
Jul 11, 2015 10:09 AM
DieselDan370
Jun 8, 2015 06:21 PM
ReckONE
Feb 25, 2015 09:41 AM
mcclusk
Feb 21, 2015 09:50 PM
