No Boost !!
Old May 7, 2010 | 08:10 AM
Diesel power's Avatar
Default No Boost !!
My buddy has a 2005 f-350 4x4 auto 6.0L , He put new ,turbo and cumputer on it and still no boost. What can we look for ? Any help would be great.
Old May 7, 2010 | 09:44 AM
SD207434's Avatar
have you checked for a manifold leak? is there a programmer installed? any other mods?
Old May 9, 2010 | 04:44 PM
Not sure if it has a programer i will try to call him. If it does would that have anything to do with no boost?
Old May 9, 2010 | 05:16 PM
Mdub707's Avatar
Were the boots inspected real good on the CAC tubes? They tend to leak on the bottom side and you'd never see it unless you took it off.
Old May 10, 2010 | 09:55 AM
SD207434's Avatar
Have you checked the intake and exhaust is there any plugging with either? If either one is then you will suffer the same.
Old May 10, 2010 | 10:43 AM
Dieselhead Jake's Avatar
Definently inspect the CAC tubes, this same thing happend to my friend..he finally put the boots on right and it finally had the right amount of boost
Old May 10, 2010 | 11:55 AM
MUDSTROKIN''s Avatar
And make sure the y pipe and turbo inlet are sealed allt he way around. I'm having this problem right now... Can't seem to get them sealed together correctly
Old May 11, 2010 | 08:28 AM
thanks for the info guys, il tell him to look at that
Un4givn
10
Apr 27, 2015 01:58 AM
chaoticape
Jan 4, 2015 05:35 PM
ash23k
Dec 30, 2014 08:31 PM
Tsgbk9
Dec 23, 2014 11:54 AM
Crews8r
Dec 21, 2014 07:35 AM
