transfer pump
Old May 6, 2010 | 08:25 PM
matts94's Avatar
Default transfer pump
hey i was wondering what would cause my fuel pressure gauge to fluctuate between 15 and 25 psi at idle the needle bounces back and forth quickly also does this while driving but a lesser amount. was only bouncing a few psi for a few months. started truck yesterday and its going crazy. is my transfer pump smoked? any ideas would be helpful? if pump is junk what are you guys running?
Old May 6, 2010 | 08:41 PM
tltruckparts's Avatar
i run an airdog and have zero problems at all i love it. but as with your gauge, alot of people put a snubber valve before the sender for the gauge, because the pulse of the fuel flow can sometimes cause them to go haywire
Old May 6, 2010 | 09:59 PM
You need to install a needle valve or a pressure snubber ASAP or you will bugger your guage. Get a needle valve and run it barely cracked open.
Need details on how you fp gauge is installed. Electric or mechanical? Isolator/no isolator? How is it plumbed in? Need details.
Old May 8, 2010 | 09:23 AM
matts94's Avatar
my gauge is mechanical, and i am running an isolator,plumbed in using a tapped banjo bolt in the inlet line on the top of the stock fuel filter housing. i have the filter relocation kit. where do you get needle valves or a snubber?
Old May 8, 2010 | 11:38 AM
You could have some air in the boost line from the isolator to the gauge.
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
landon025
Sep 8, 2015 09:21 PM
HardLuck
Jun 24, 2015 08:04 AM
Renteria1217
Apr 16, 2015 11:38 PM
B.k. Smith
10
Jan 7, 2015 02:29 PM
