adrenaline 4k questions
Old May 6, 2010 | 03:56 PM
outlaw1_gt's Avatar
Default adrenaline 4k questions
Got some questions on adrenaline 4k
anyone upgrading? Is it worth it? and how much? can the pulse just be upgraded to new buttons?
Old May 6, 2010 | 08:44 PM
LawnScum's Avatar
im gonna do it with mine. i can already wrap 4k with the torque tune. if you do the 4k i recomend 60 or 110 pound valve springs.
Old May 6, 2010 | 08:45 PM
biged681985's Avatar
from a different site, i seen its supposed to be 150 bucks and u have to send them the adren module, the pulse can be updated over the computer
Old May 6, 2010 | 10:22 PM
Depending on the age and condition of your Adrenaline it can be upgraded for $0 to $150.
Old May 7, 2010 | 12:03 AM
mainman300's Avatar
will it still pull hard at 4k?
Old May 7, 2010 | 09:58 AM
Nor_Cal_Angler's Avatar
To me that would be the question of question's......just cuz it peg's 4k here and there...at what point will it stop putting power to the pavement????
Old May 8, 2010 | 12:15 AM
Unless your sled pulling you dont need to turn 4K.
Old May 8, 2010 | 03:47 PM
Diesel Dummy's Avatar
This was in the email i got about, just read it carefully, if you are looking for smooth dont bother!!!
The Adrenaline 4K will be offered both as a new kit and as an upgrade option. If you already own an Adrenaline and would like to have it modified to be a 4K box, please go to the
Quadzilla Adrenaline 4K Upgrade page listed on the Quadzilla homepage. Charges for the upgrades for existing owners will range from $0.00 - $150.00 (plus shipping) depending on the serial number and age/condition of your Adrenaline.
Now for all of the details of the Adrenaline 4K boxes:
* The $150 upgrade charge on older boxes will include a brand new board as well as a new 1 year warranty.
* Once an Adrenaline is made into a 4K box, it will only work with the dedicated 4K tunes. Previous tunes (such as the Beta, 1000, and 2000 series) will not work on the Adrenaline 4K or Pulse.
* Your Pulse Monitor must also be updated (online software available) to the 4K software in order to work with your Adrenaline 4K.
* In order to modify an existing Adrenaline, your board will have to be sent to Quadzilla for modifications that can only be performed by a Quadzilla Technician.
* The 4K programming completely takes over the VP44 control and therefore may not be as smooth as a regular Adrenaline module.
* The Adrenaline 4K is intended for OFF-ROAD use only and are not to be used on any public roads or highways.
* The Adrenaline 4K is not intended for stock trucks: AFTERMARKET VALVE TRAIN MODIFICATIONS REQUIRED AT THE MINIMUM. INTERNAL ENGINE MODIFICATIONS ARE ALSO RECOMMENDED.
* The Adrenaline 4K will set a Check Engine light and may be rough in areas approaching the factory rev limiter.
* The Adrenaline 4K is intended to be used in conjunction with a Pulse monitor.
Upgrades on modules with a serial # prior to 63553 will be a $150 charge.
Upgrades on any modules with a serial # between 63553-70200 will be no charge.
All serial #'s after 70200 will not be eligible for upgrade.
Quadzilla Performance Technologies
Quadzilla Performance - Home 1-888-842-6572
Jun 11, 2021 12:36 PM
Mar 20, 2015 08:20 AM
Jan 13, 2015 09:00 PM
Nov 28, 2014 09:50 PM
Nov 12, 2014 08:10 AM
