possible turbo problem
Old May 5, 2010 | 10:59 PM
IkillforFOILES's Avatar
Default possible turbo problem
hey guys i have notice recently some troubles with my turbo.
heres the breakdown. i will drive my truck for about 15-20 minutes with the turbo working fine good whistle and all. however all the sudden my turbo will just stop activating, like its clogged or something. no matter how hard i floor it the turbo will not spool up =/. i have no idea what it is, some help would be great
Old May 5, 2010 | 11:07 PM
2MuchJunk's Avatar
There is a few things it could be. 1 is the cat is clogged if it is still on it I would remove it any way. You could have a vac. pump going out. Pull the vacuum line off going to the turbo solenoid and check for vacuum there. Your turbo solenoid could be going out.
Old May 6, 2010 | 09:27 PM
Adam65's Avatar
I am looking for info on makeing my own "turbo master" or mechanicaly controlled waistgate. You might want to do the same. I just did a remote pmd and found the hard plasic vacume lines going to the turbo were britel like crazy and broke them taking off the intake manifold. Durring my test drive i had no boost. I would check them very closely.
Old May 6, 2010 | 10:00 PM
2MuchJunk's Avatar
93 yours should have a mechanical waste gate.
burndiesel
10
Feb 7, 2023 01:15 AM
avatardvr
18
Aug 8, 2019 12:38 AM
Hogridenfool
Nov 20, 2017 04:37 PM
n2brk
Feb 21, 2015 09:05 AM
GreenDieselF
Oct 20, 2014 02:05 PM
