3rd gen (2003)How to enable the High idle?
Old May 5, 2010 | 06:56 PM
chadillac's Avatar
Default 3rd gen (2003)How to enable the High idle?
A friend of mine is wanting a high idle for his truck.Is there a way to do this ?This has a throtle cable not sure of the proper name but hopefully someone will chime in.
Old May 6, 2010 | 09:17 PM
GhostRider3149's Avatar
I'm sure you know about this but.....when it's colder out (i forget the certain temp.) it will or should jump to 1k RPMs. If he wants more than that...i guess he's gonna have to go aftermarket. Also just a thought, i know it works on tractors but i have never tried it on anything smaller such as pickups really, he could try setting the cruise at a higher idle
Old Jun 25, 2010 | 05:35 PM
340duster's Avatar
If the dealer has enabled it, it works with the cruise control buttons. Cruise on will start it and use the accel button to bring it up 100 rpm at a time. The decel button shuts it off.
Old Jun 25, 2010 | 06:37 PM
trynto's Avatar
Won't work on early '03... I tried... not in the ecm... some say it will work on some of the later '03 trucks...
Old Jun 26, 2010 | 12:53 AM
00CamaroSS's Avatar
I was wondering about this too. I tried what 340duster said and it didn't work. So I guess I will have to take it to a dealer and have it turned on. Although I saw that the Diablo T1000 can change the ecm programming (and enable high idle among other things). Does anyone have one or know if it will work(or how well)?
Old Jun 26, 2010 | 11:09 AM
scrappy's Avatar
I tried too on my '03.5 that had an April 03 build date. No dice
Old Jun 26, 2010 | 03:03 PM
cerberus60's Avatar
If you have a truck built before Dec 10 2003 you will need to reprogram the ECU to get the high idle. There is a range of ECU numbers before that date that will need to replace the ECU with a new one that will accept the programming that has the high idle in it.
Getting it to function correctly may also require the correct type of CC to activate it.
Old Jun 26, 2010 | 05:44 PM
05 dodge's Avatar
That is how it works on my 05
Old Jun 28, 2010 | 07:12 AM
scrappy's Avatar
if you have a Smarty it is enabled in the programmer instread of having to go to the dealer to enable it.
Old Jun 28, 2010 | 07:47 AM
cerberus60's Avatar
Can't be enabled if the base code is not in the ECU. If the ECU is too old the base code cannot be loaded into it. The CC also has to be the correct one to end the signal to the ECU to ramp the idle.
There many differences in code bases and capability of the ECU's from 03-07, its not a given what works on one will work on all.
john grossman
10
Jan 12, 2019 08:58 PM
robbyS
Apr 16, 2015 02:22 PM
CumminsCoalRoller24/7
Feb 21, 2015 10:44 PM
robbyS
13
Dec 20, 2014 04:25 PM
stephenthinnes
Dec 6, 2014 01:03 PM
