what turbo
Old May 5, 2010 | 01:44 AM
mylilpwny's Avatar
Default what turbo
hey yall i was wondering you take on what i should do for turbo wise ... i am wondering what would be better a 35/40 hybrid or just a hx 40 turbo ?
Old May 5, 2010 | 02:11 AM
12vcummins96's Avatar
they are the same thing what are your plans for the truck also i couldnt help noticing you have 5k springs in your truck
Old May 5, 2010 | 02:33 AM
mylilpwny's Avatar
dont really plan on going more then 350 hp ... maybe 400 tops ... but just want to up the charger a bit cuz i know that the 12cm housing can be a bit restrictive once upgrading from what i have read and been told ... so then i could just find a stock hx40 and swap it in ? what mods would i need to do (other then the 4'' dp since i already have one )
would the hx40 be a decent upgrade for the price ... i have found a few for around 300 bucks
Old May 5, 2010 | 06:59 AM
12valvetater's Avatar
Search
Old May 5, 2010 | 09:26 AM
cumminspwr11's Avatar
if you go with a tru 40 you will have to get a new downpipe, your stock turbo uses a 3.5" v-band flange and the 40 will use a 4" one, i had a tru 40 on my truck when i just had a #5 ff and it was so slow to spool, i think you need a bit a fuel to run one efficently?
just a question but wouldnt get a bigger exhaust housing be a good upgrade for an application like this? they only cost like 250 for a holset one and bolt right in, like a 14 or 16cm one? you spool would be quicker than a 40 with a 18 and your egts would be low enough
Old May 5, 2010 | 09:34 AM
rkadcock's Avatar
N.M. Bombers Director
That power goal would be easy to hit with a set of 5x12 injectors and a Aurora 3000 turbo which is a 58mm. With the right AFC tuning that'd put you close to the high 300s/low 400s. That is quick spooling and I think for that setup you'd really like it. Yeah its a little pricey but that includes the downpipe as well. Also if you ever want to upgrade, then just add the Aurora 5000 and you got a nice compound set up.
Old May 5, 2010 | 06:23 PM
mylilpwny's Avatar
ya im not lookin to spend like 1500 bucks ... was wanting like under 500 .. thats why i was wondering if upgrading from the stock 35 to like a stock 40 would be better or get a different comp housing ... eventually i would like to up to a much better turbo but for now its mostly wanting to help with egts a bit ... they arent out of control ... but want to keep them in check expecially before i get injectors
Old May 5, 2010 | 10:22 PM
rkadcock's Avatar
Upgrading to the 40 will help keep your egts down a good bit. Right before I did my pump rebuild and tore down my engine this past winter/spring I dynoed 392/974 with 4k GSK 0 Plate in stock location, tuned AFC, Marine 370s (5x12) and my hx35 but that setup pegged my pyro in a matter of seconds, it might have been a little different if I had a set of 370s that had the correct spray pattern but for $250 they were a nice boost in power
Old May 6, 2010 | 10:48 PM
ltr450's Avatar
put a 3rd gen turbo on it
Old May 6, 2010 | 10:53 PM
94 12valve's Avatar
if he can do some minor fabbing than yes a turbo off a 04.5-07 cr would work great. HE351CW
