Trac bar issues
Old May 4, 2010 | 04:20 PM
01cummins13's Avatar
Default Trac bar issues
Ok so I had to put a trac bar on my truck when i bought it almost two years ago, and now it needs another one. I know the mounting spot wears away and it destroys trac bars but is there a way to solve this problem? Or do i just bite the bullet and keep replacing them?
Old May 4, 2010 | 05:25 PM
DT Pro Fab Trac Bar
Old May 4, 2010 | 06:01 PM
can you get me a price on that Luke? or let me know where i can get one? thanks
Old May 5, 2010 | 07:37 AM
J-Pipes's Avatar
Try giving Ken McCabe a call at 740-342-5007. He rebuilds them, he rebuilt mine about 37k miles ago and I have had no problems, it is considerably cheaper than a new bar, when I did mine in late 2007 or early 2008, it only cost me around $150 to have it done, or he will more than likely just sell you the kit if you want to do it yourself. Good luck.
Old May 5, 2010 | 10:09 AM
what all does he do to rebuild it? im pretty sure the mounting spot on the drivers side is what is destroying mine.
Old May 5, 2010 | 03:15 PM
J-Pipes's Avatar
A new poly bushing for the solid mount, and then he punches the guts out of the ball joint end, and sleeves that end with a cast aluminum housing, that is then assembled with the guts for a new ball joint assembly that is greasable and comes with 4 or 5 shims to tighten it back up whenever it starts to wear, although mine is still tight. If you deside to call him you'll have to wait till the morning he is working second shift this week (he changes shifts weekly), he leaves for work around 1-1:30. Tell him Jake gave you his number.
Old May 5, 2010 | 06:07 PM
ok but thanks for your help! ill let you know what i do. It might be sold soon but if not i think ill send it to him
dwmeehan
Jan 29, 2025 12:13 PM
CGwill
Jan 26, 2015 02:10 AM
Polaris04
Dec 1, 2014 08:27 AM
12vbomber
Nov 11, 2014 10:58 AM
motormayhem
Nov 1, 2014 01:24 PM
