Transfer Sled Pulling Diesel Discussions of Transfer Sled Pulling , Set Up , Designs , Practices , Techniques , Tips and More
*PLEASE DO NOT POST FUTURE EVENT DISCUSSIONS IN THIS SECTION*
Pulling my 06 dodge for the first time this weekend
Old May 4, 2010 | 06:18 AM
commonrailcummins13's Avatar
Default Pulling my 06 dodge for the first time this weekend
Im pulling my 06 Dodge 3500 this weekend for the first time. Ive pulled before but this is my first time with a manual tranny. Just looking to see if anyone has some thought on 4-high or 4- Low and what gear use suggest. any suggestions would help me greatly.
Old May 4, 2010 | 07:21 AM
Diesel Dummy's Avatar
well you should have 410's for gears so 4th low is what i would try first, you should be fine with that with what you have done. If your clutch has been in a while then utilize it to its fullest potential, and rev and slowly let out to get you moving, just make sure you dont leave early before your rpm's are up so you stay under the turbo, but since its the stocker you should be just fine.
OH AND DONT WATCH YOUR PYRO!!!!!!!
Old May 4, 2010 | 09:02 AM
96cummins06crd's Avatar
is your truck a 5.9 or a 6.7 ?
Old May 4, 2010 | 10:21 AM
GetBlown5.9's Avatar
Mount Joy, Pa...would you be going to the buck?
Use 4th gear, 4-low range whether you have 4.10 or 3.73. its the best over all gear in the 6spd.
When you get hooked up to the sled point your drivers mirror so you can see your rear wheels.
Bring your rpms up to about 3500 and slowly but steadily start to let the clutch out, you will hear the motor start to load and the truck will begin to roll, watch your tire and about the time you make a full revolution you should be all the way off the clutch. You shouldnt slip it for more than about 3-5 seconds (it happens quick)
Here is a video so you can see about how far I let it roll before the clutch is all the way locked up.
Old May 4, 2010 | 01:12 PM
94 12valve's Avatar
YouTube - TJ Bates One Piece At A Time
This is the same great advise he gave me when I first started. Was good then and still good now
Old May 4, 2010 | 09:21 PM
thanks guys i appreciate it yes im going to the buck. Its a 5.9 the 6.7 didnt start til 07. Ill give it a whirl with the advice yous gave me thanks again i appreciate it.
Old May 4, 2010 | 09:40 PM
94 12valve's Avatar
i'll be up there arround noon and Tj will be there shortly after for a pre game cook out with quite a few other members. Feel free to come on up and hang out before and after the pulls.
Old May 4, 2010 | 09:46 PM
iker42's Avatar
dave, wanna throw an exhaust housing on my truck?? haha.
Old May 4, 2010 | 09:49 PM
94 12valve's Avatar
bring it up and I'll guide you through it. It will all depend if the 4 mounting bolts will come loose. I'll be up there at noon the sooner you get there the better
Old May 4, 2010 | 11:13 PM
alright if i get a chance to head there a little early i might just swing by if not i wont be there til four thirty or so. but im sure ill see yahs around either way.
