04 F250 6.0 Won't Start
Old May 3, 2010 | 12:19 AM
jpick782's Avatar
Default 04 F250 6.0 Won't Start
I have a 2004 Ford F-250 Powerstroke 6.0L and went to work the other day I shut my truck off and it hasnt started since. I replaced the fuel pump relay and the cam shaft positioning sensor and all it does is turn over. Any Idea's?
Old May 3, 2010 | 12:29 AM
Mdub707's Avatar
Is there any reason you decided to replace those? Any codes? How many miles, any programmers or anything else on the truck?? More details...
Old Jun 1, 2010 | 04:08 PM
ATX6132's Avatar
check ipr valve that was my reason..
Old Jun 8, 2010 | 10:33 PM
Karls03's Avatar
Checking the fuses got my 03 running again.
Old Jun 8, 2010 | 11:08 PM
FRIDAY88's Avatar
sometimes CEL wont be on display scan truck and get codes if any, also need symptoms of how it was running before shut off,, I agree with Mdub707 more details
Old Jun 8, 2010 | 11:09 PM
Rustin's Avatar
Is your fuel pump working? PM me it might be something simple.
Old Jun 12, 2010 | 01:46 AM
frpman55's Avatar
on my truck ac compressor was causing engine to turn over too slow.try removing belt and see if it starts.
Old Aug 6, 2010 | 02:52 PM
jpick782's Avatar
I have done a lot to the truck and it still is not running. Here is the list I changed my FICM got the truck running for a little while then after changing the EGR cooler to a delete kit the truck stopped running again. I changed the IPR valve TWICE hoping it was the problem and the truck would start but only run about 10 minutes. It is like when the truck runs and the oil gets warm and thins out the truck shuts down. I am still not throwing any codes but have a ford mechanic friend that was running the computer on the truck so we could test the High pressure system we got 800 PSI on one side and 1000PSI on the other. We got the truck started and after a few minutes it ran great after we shut it down I asked him to try and start it again and it wouldnt it would only get 350 psi. I did an oil change and got the truck to run for 45 minutes sitting there at Idle then it shut down. The next day I took it out and it ran for about 5 minutes then I had to be towed home. I have the engine torn down now and I tested the High pressure system with air for leaks we heard something on both sides so put some oil dye in the system and put the air to it again. I have what looks like two leaks where the high pressure rail connects to the fuel injector. One on each side right the closest to the firewall. So just about everything has been replaced including the Cam sensor so any ideas from anyone because I have stumped the Ford Mechanic.
Old Jul 12, 2012 | 04:15 PM
doordog's Avatar
Up at wits end
i have a power stroke pro if you want to call and hit him with what you did and what it's not doing he will solve i am sure.
his name is Chris he works at Diesel Doctors in Georgetown his number is
Hope this helps
Cheers
I removed the number for a couple reasons. You have no posts here and offered no help other than getting your buddy some side work who isn't even on the site or a paying sponsor. Another reason is, your buddy probably doesn't want all the spam phone calls he'll be getting with his number out in the interwebs.
Thanks, Mdub707.
Old Jul 12, 2012 | 05:09 PM
1964Horseman's Avatar
You will definitely have to fix your high pressure oil leaks at the injectors first. The original kits can be had from the stealership for about $5.00 each.
Then do another pressure test and see if there are anymore leaks. Understand that the leak does not have to be very big. It is a pressure issue and not volume. Without a min of 500psi during crank, injectors will not fire and you will probably eventually throw icp, ipr or various injector codes unfilled the leaks are fixed.
Damn auto correct! That was supposed to say the "O ring" kits.
Last edited by 1964Horseman; Jul 12, 2012 at 05:09 PM. Reason: Automerged Doublepost
