Turbo Specs
Old May 2, 2010 | 09:40 PM
BIGREDGOAT's Avatar
Default Turbo Specs
Does any one have the specs for my stock first gen turbo?
Old May 2, 2010 | 09:51 PM
12vcummins96's Avatar
53/60/18 or 21depending if auto or manual
Old May 2, 2010 | 10:23 PM
BIGREDGOAT's Avatar
its a manual
Begle1's Avatar
Inducer Side: Sucks
Exducer Side: Sucks
A/R Ratio: Sucks
Turbine Diameter: Sucks
Impeller Diameter: Sucks
Mass Air Flow: Sucks
Weight: Acceptable
Wastegate: None
MTBF: Sucks
Old May 2, 2010 | 10:32 PM
its a 21
Old May 3, 2010 | 12:43 AM
TTipsword's Avatar
Originally Posted by Begle1
Inducer Side: Sucks
Exducer Side: Sucks
A/R Ratio: Sucks
Weight: Acceptable
Wastegate: None
MTBF: Sucks
might be the most normal thing outta begle yet!
Old May 4, 2010 | 10:08 AM
Levi Miller's Avatar
well mine has a waste gate and it still six i dont make much boost butt i ren about 11 psi and the most i can get outa it is prolly 18 or 19 im just going with a 60mm compressor upgrade for 250
Old May 4, 2010 | 10:19 AM
tltruckparts's Avatar
if your only seeing 18 or 19 out of it you got a problem somewhere. mine did 20 stock. and did about 35 before i pulled it out. you probably need a boost elbow on there to mess with the wastegate
Old Sep 29, 2010 | 12:57 AM
jwirth's Avatar
I got 29psi out of mine with just dennyt pin and 3200 rpm spring.
Old Sep 29, 2010 | 01:04 PM
cumminskid92's Avatar
mine says it is an H1c but i am pretty sure it is a hybrid. it has a wastegate and i have seen well over 40psi boost on two different guages and still holding up.
avatardvr
18
Aug 8, 2019 12:38 AM
Hogridenfool
Nov 20, 2017 04:37 PM
Finn92
Feb 24, 2015 10:41 PM
n2brk
Feb 21, 2015 09:05 AM
GreenDieselF
Oct 20, 2014 02:05 PM
