INJECTORS
you may want to talk to to a pump / injection shop? I wonder if they can re calibrate or replace nozzles to the correct specs for your engine/pump. I realize that the last post was months ago. I hope that you got it fixed!!
gonzy
gonzy
i got it fixed it was the manual primer pump the plunger was broke so it wasnt priming to the corect pressure so i replaced it cracked open the injector lines and she started right up, checked for leaks, it smoothened right out and she has ran fine since then. i just have some fine tuning to do now with the full power, smoke screw, and the star wheel
klein444
Mar 8, 2015 11:42 AM
