tapping pump?
Old Apr 28, 2010 | 08:37 AM
98dodgecummins's Avatar
Default tapping pump?
does tapping the pump put any additional strain on the pump even when the chip is turned off. when im not using the chip could i just untapp the pump whenever i dont want to use the chip because untapping it would make it easier on the pump?
Old Apr 28, 2010 | 09:13 AM
Farmboy 2.0's Avatar
The reason to pump is tapped is for your tuner to tell your pump to add timing and fuel. But if your tuner is turned off its not sending anything to the pump. So it shouldn't hurt the pump at all. My VP has had two different tuners on it and no VP problems or failures knock on wood. Hope this helps
Old Apr 28, 2010 | 11:20 AM
what setting is for fuel and timing on the comp flashing setting and solid setting.which one is which?
Old Apr 28, 2010 | 06:22 PM
On a comp I have no idea. On my juice the higher settings you go the more fuel and timing is added.
Old Apr 28, 2010 | 07:28 PM
Solid is the power level. Flashing is low boost fueling setting.
Old Apr 30, 2010 | 08:53 PM
dennhop's Avatar
The Comp does both fueling and timing automatically, there is no adjusting the two separately. Like Lukesdiesel said, the solid bars are for the power levels, and the flashing bars are for the low boost fueling within each level, but once those are set, the fuel/timing is automatically adjusted to that setting.
Old May 3, 2010 | 08:43 AM
oh ok
Old May 3, 2010 | 07:54 PM
dennhop's Avatar
you're going to need to keep an eye on that fuel pressure gauge, cause if you're around 10 11 on lvl 3, the ddrp is already having issues keeping up with the Edge.....
Old May 3, 2010 | 09:46 PM
wheres the cheapest raptor pump i can get ?
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
landon025
Sep 8, 2015 09:21 PM
HardLuck
Jun 24, 2015 08:04 AM
Renteria1217
Apr 16, 2015 11:38 PM
greenbomb
Jan 23, 2015 10:36 PM
