How to keep from getting P0238 code
Old Apr 26, 2010 | 11:40 PM
2001Disel's Avatar
Default How to keep from getting P0238 code
Ok so i have a edge juice w/ attitude and with the map sensor either connected or not the code still keeps coming back. The engine runs fine but code is always there. anything i can do?
Old Apr 27, 2010 | 01:02 AM
12vcummins96's Avatar
replace the map sensor
Old Apr 27, 2010 | 07:25 AM
RAW's Avatar
RAW
Before throwing money into parts, check the wiring between the sensor and the ECM, also check the resistance of the MAP sensor. Of course a multi meter is required for these steps.
Old May 16, 2010 | 12:49 AM
pgall's Avatar
I have the same problem. I have replaced my map sensor three times and the problem keeps coming back. Now the light stays on and the truck will not excellerate at times. It will last for a few minutes up to 10 or 15 miles. When it releases it runs like it should. It is very inconsistent but starting to happen more often and for longer distances. If I am pulling a hill and it acts up I am lucky to do the speed limit. Please help. I have spent alot of time and money tring to figure it out and no one seems to have an answer. Thanks
Old May 16, 2010 | 02:22 PM
Sounds like a bad connection to the MAP sensor.
Old May 17, 2010 | 05:06 PM
dukeboy_318's Avatar
I had a similar issue, after replacing connectors and the sensor itself , i did some checking and found that even with my key off and removed, the ECM is staying on and drawing power through the entire system and after each time that id clear the code and shut the truck off, itd come right back on as soon as i started it the very next time so as a temporary fix until i figured out why its stuck on, i simply hard wired my box diredctly to the battery post, kinda sucks cause it stays on all the time . Sounds like maybe you are having a similar problem.
P.S the reason it trips the MAP sensor in this case is because if the ECM is trying to read the map sensor and there is a box plugged into it and the box is off, it keeps the ECM from being able to read it until the truck is started again
Old May 17, 2010 | 09:19 PM
pgall's Avatar
Default One more issue
Now not only do I have the map sensor problem, my fuel pressure gauge went to zero today and wouldn't recover. I drove about 10 miles to get to work and it kept running. Any one know how long it would take with no fuel pressure to take out the injector pump? I am thinking if it had no pressure for that long that it would have quit running. Mabye it is my gauge. Any thoughts?
Old May 21, 2010 | 12:09 AM
mxtuner1's Avatar
Dear pgall- Your injection pump will run for a surprisingly long time with the lift pump bad. The main problem is that it is not drawing enough fuel to cool itself and return heated fuel back to the tank. Pretty soon parts overheat and it will fail completely. You will have a harder time starting it when it is warm - that is a good sign that the lift is bad. BTW don't always think the lift is bad when the guage reads zero - I know it scares you when you see it - but on my truck the wire came off the FASS pump so it was not pumping. I replaced the wire and mounted it better and viola! All is well. Besides the FASS, Airdog, and raptor there is a gear driven pump by glacier that looks really nice and price is good. Good luck and fix the lift situation soon.
dwmeehan
Sep 6, 2015 04:20 PM
Saams69
Jul 20, 2015 11:21 PM
flash7210
Jul 5, 2015 09:25 AM
robbyS
Apr 16, 2015 02:22 PM
Backhoeman
Jan 3, 2015 12:53 PM
