edge comp setting?
Old Apr 26, 2010 | 09:14 PM
98dodgecummins's Avatar
Default edge comp setting?
what is the best setting for smoke?
Old Apr 27, 2010 | 02:54 PM
Power Level 5
Low Boost Fueling 5
Old Apr 27, 2010 | 04:26 PM
Matt Tex's Avatar
Really smokes dumb without power and if you cant figure out what level fuels the hardest and will produce the most smoke I doubt you have a good LP and probably dont even have gauges but have fun.
Old Apr 27, 2010 | 10:17 PM
no i have gauges and i know what my fuel pressure is i never let it go below 10 psi. so dont get pissy.
for some reason when i go to the flashing setting a i set it on 3 then i go to change the solid setting to 3 then i go back to the flashing settings its on 5 when i only set it on 3 it only does that sometimes. what could this be?
should the comp and 65 hp injectors be this powerful i was going down the road at 55 and im on lvl 3 of the comp and i start crowding the fuel and it slips the tires on dry pavement should it be that strong i didnt know it would do that?
Last edited by 98dodgecummins; Apr 27, 2010 at 10:17 PM. Reason: Automerged Doublepost
Old Apr 27, 2010 | 10:19 PM
Red_Rattler's Avatar
High Tech Redneck
Set it to broke (Thats what your tranny might do) Fill out your sig so we all know what you are workin with
Old Apr 28, 2010 | 07:32 PM
Each level 1-5 has its own low boost fueling setting. As an example. If you have it on level 5 with low boost fueling on 5 and switch to level 4 if you want it to have low boost fueling of level 5 then you much change it on each level.
Old Apr 29, 2010 | 08:03 AM
dodge rodder's Avatar
dont know that much about the edge comp but i am more than happy with the quadzilla adr.. the power is super good and the smoke is way to much for the street. just remember smoke means big egts and that mean new turbo
Old Apr 29, 2010 | 08:38 AM
no i dont mean it that way i mean when i put the solid bars on 3 then i go to switch it to my flashing setting and when it pops up its on lvl 5 then when i put solid bars on lvl 4 i go back to flashing setting its on lvl 1 . whats wrong it does it by itself?
Old Apr 29, 2010 | 10:58 AM
01quadcab's Avatar
you have a fuel setting aka the flashing bars for each power level aka the solid bars. So you have to set your prefuel level for each power level. So if you set level 1 solid bar and then change prefuel (flashing bars) it's only set for level 1 you change to power level 2 your prefuel is set different and must be adjuster for each power level the way you want it.
are you sure the tires are breaking loose, and not slipping something in the trans? I haven't had that issue with my truck.
Old Apr 29, 2010 | 03:57 PM
my truck is a 5 speed?
