I'm Going All Out
I've had the brake pads (front and rear), along with 7 qts of 75-90 gear oil, 6 qts of ATF+4, 2 qts of brake fluid on the shelf. But now, I went and got 3 gals of coolant (Mopar), a new water pump, brand new, not remanufactured ($50 from NAPA w/ a lifetime warranty), new coolant hoses (upper and lower rad and both heater hoses), new valve cover breather filter, and a new radiator cap. So if anyone is bored, in the area, and wants to make a little money, I'm gonna need a little help replacing parts.
Coming soon: upper and lower ball joints, tie rod ends, steering stabilizer, and shocks. Then fix the HVAC system (mode and blend door motors), service the A/C system, service the transmission, and a new multi-function switch.
