edge comp and codes?
Old Apr 25, 2010 | 05:14 PM
98dodgecummins's Avatar
Default edge comp and codes?
hello i finally got to scan my truck after putting the comp box on and the codes that popped up were 1690, 1682 0122 0238 0234 what happens if your map sensor voltage is too high because 0238 is that one? im worried about the code 1690 because it says fuel injection pump ckp sensor does not agree with ecm ckp sensor would the chip make it throw these codes the very first time i unplug everything and plug the wires for the comp box the first time?
Old Apr 25, 2010 | 07:45 PM
Double Check All your connections.
Old Apr 25, 2010 | 08:57 PM
what would cause the 1690 code?
would my connection being loose at where i tapped the pump would that effect anything? i got a stealth plate? but the nut seems to get loose? where it connects
at where i plug in the map sensor the plug in is a little loose where the edge connection snap in deal comes with is a little loose but its all the way in and has a little pop on deal.
what would also cause the apps code voltage to low?
Last edited by 98dodgecummins; Apr 25, 2010 at 08:57 PM. Reason: Automerged Doublepost
Old Apr 25, 2010 | 09:46 PM
Bad APPS
Old Apr 26, 2010 | 08:38 AM
so your saying my tps/ apps sensor is bad? what about the 1690 code?
