torque converter lock switch
Old Apr 24, 2010 | 09:15 PM
DEERE2500's Avatar
Default torque converter lock switch
was wonderin what wire u splice into for lock up on 48re? im just runnin a straight switch, i also pulled plug off trans and it had transfluid inside of plug, dunno how, no leaks anywhere
Old Apr 25, 2010 | 04:52 PM
poediddly83's Avatar
What year is your truck...color change by years.
If you look at your plug(inside) it will have numbers stamped on it. The number 7 wire is what you want to T-tap into.
From the T-tap run a wire into your cab and solder in a 33 ohm resistor. Hook it to a SPST switch and ground the other pole of the switch under your steering column. The resistor will keep you from throwing a CEL.
In sum...T-tap into #7 wire, run wire into cab w/33 ohm resistor, attach to a SPST switch, and ground the switch to the screws under the steering column.
Old May 17, 2010 | 01:07 AM
josh03cummins's Avatar
this works great by the way been on mine for a few weeks helps some on fuel milage and stops constant down shifting...... i wouldn lock it in the low gears unless you got a built trans
Old Jul 22, 2010 | 07:05 PM
DEERE2500's Avatar
thanks, got it hooked up, works fine, just tryin to get use to it, gonna try it at the strip soon
cumminspwr11
12
Oct 17, 2021 03:50 AM
rstrange1996
Sep 22, 2015 01:25 PM
twwtruck
19
Apr 7, 2015 05:14 PM
Cody Cain
Dec 22, 2014 01:27 PM
Cody Cain
Dec 21, 2014 06:50 PM
