Troubles...
Old Apr 23, 2010 | 10:06 AM
4x4DREAMER's Avatar
Default Troubles...
Hey guys, I have got some wierd things going on with my truck. First it shut down on me going down a road. So I had the fuel filters changed and a week later it would not start up while I was at the dump taking my trash off. I tried it a few times and it just would not start. I then turned the key over enough to use my pmt and turn it up to performance and it started. I got home looked under the hood and noticed there was a lot of battery acid on the nuetral battery clamp on the drivers side so I took it off and noticed that the clamp was broken on the bottom side but still making a connection. I dont know if this would have anything to do with it but thought I would let you know. Can anyone shed some light on what might be going on.
Old Apr 23, 2010 | 10:37 AM
MUDSTROKIN''s Avatar
Does it start normal when it's cold?
Old Apr 23, 2010 | 10:58 AM
4x4DREAMER's Avatar
It has been.
Old Apr 23, 2010 | 11:11 AM
Mdub707's Avatar
I would get new connections for your batteries ASAP, then try it again. The FICM needs a constant 48 volts to fire your injectors, could have easily been part of your issues.
Old Apr 23, 2010 | 11:16 AM
Matt Tex's Avatar
I dont know if the 6.0s have problems with the CPS like the 7.3s but thats kind of what it sounds like.
Old Apr 23, 2010 | 12:01 PM
4x4DREAMER's Avatar
dont know how to post apic but I took the battery cable off and it looks bad, I also noticed that there is a pin hole in the battery next to the post.
Old Apr 23, 2010 | 03:12 PM
That sounds like it could be part of the problem... if you fix that and it's still not wanting to run when hot. I would check your STC fitting i believe is what it's called. they're known to go bad and not let the engine run when up to operating temps
Old Apr 23, 2010 | 03:16 PM
Diesel Powered Rocket's Avatar
This all makes sense. The cracked battery terminal being loose, allowed it to arc and burn a hole in the top of the battery. Replace the cable, clean off the top of the battery and use a dab of flashing cement (tar) to seal the hole in the battery. Make sure the rest of your terminals are tight as long as you are under the hood. Low voltage = No start.
Old Apr 23, 2010 | 03:51 PM
4x4DREAMER's Avatar
Thanks for the help hopefully that wil do it.
Old Apr 23, 2010 | 05:06 PM
Mdub707's Avatar
Have your batteries load tested. If they're old it might be a good time to just replace them. Weak batteries are thought to really strain the FICM and burn it out prematurely.
