comp box with fass ddrp lift pump?
Old Apr 22, 2010 | 07:32 PM
98dodgecummins's Avatar
Default comp box with fass ddrp lift pump?
i was surprised on lvl 5 getting on it the fass ddrp held fuel pressure is 8 psi ok to be at i know factory is 5 psi and everyone else says 10 psi how much life does a tapped pump take off on them because i might just leave it unplugged? does my fass ddrp lift pump sounds like it will keep up with the comp box?
Old Apr 22, 2010 | 07:59 PM
12vcummins96's Avatar
10 to 14 is what you need
Old Apr 22, 2010 | 09:25 PM
well most of the time it is 20 psi and 16 driving down the road then getting on it 9 to 10 . on lvl 5 what will happen if it goes down to 8 or 9 psi it shouldnt hurt nothing?
Old Apr 22, 2010 | 10:13 PM
01quadcab's Avatar
factory is not 5psi. my factory pump on my 99 made 13 at idle, cruised at 11 and ran down to 5 at wot. It's not good to run below 10. a tapped pump doesn't shorten the life span it's the low fuel pressure.
Old Apr 23, 2010 | 10:02 AM
ok but ill just be easy on the truck but the fass ddrp aint bad keeping 8 psi on lvl 5 of the comp box.
Old Apr 23, 2010 | 09:52 PM
01quadcab's Avatar
it's still not great.
Old Apr 24, 2010 | 11:36 AM
but if i dont let my fuel pressure go below 10 will i be fine?
Old Apr 24, 2010 | 11:58 AM
U can get a spring that will bump up the pressure a little on the DDRP.
Old Apr 25, 2010 | 01:25 PM
yeah but what i hate about the ddrp at idle when warmed up it idles at 20 psi, 20 isnt very good is it? it would be nice if i could get the fuel pressure down at an idle.to like 17 or 18 an idle.
Old Apr 25, 2010 | 02:59 PM
20psi at idle is fine.
landon025
Sep 8, 2015 09:21 PM
ctjkelley
Jun 3, 2015 06:01 AM
Renteria1217
Apr 16, 2015 11:38 PM
klein444
Feb 21, 2015 10:33 AM
moneypitk5
Feb 12, 2015 11:01 AM
