heater ?'s
Old Apr 22, 2010 | 02:09 PM
kegs99's Avatar
Default heater ?'s
my 99 when you turn on the a/c or the heater, it only comes out the defrost. it don't matter what you turn it to, if its on, it comes out the windshield defrost and no where else. what do i gotta fix?
Old Apr 22, 2010 | 08:10 PM
RAW's Avatar
RAW
All of your deflectors are controlled by vacuum pots. You can remove your heater control assembly, and the vacuum lines from the position switch. Check for vacuum at one of the line with the engine running. Which one I do not know for sure. If there is no vacuum anywhere, there is a break in the line between the pump and switch. From there, it may be the switch itself. More than likely a break between the pump and switch.
Old Apr 23, 2010 | 08:29 AM
Rosco's Avatar
Prolly just a vacuum line pulled off your pump. mine did it when i was in Gillette. we'll look at it tomorrow
kelchy82
6.2L & 6.5L Performance
10
Nov 27, 2016 04:32 PM
Mike H
Jan 25, 2015 10:08 AM
94_12v
Jan 4, 2015 10:37 PM
bikernut
Audio Equipment/Electrical
Dec 18, 2014 03:30 AM
Low_Life_Style
16
Nov 29, 2014 06:28 PM
