Fuel leak / oil leak
Old Apr 22, 2010 | 09:33 AM
svt28640's Avatar
Default Fuel leak / oil leak
other day i found that i had fuel mixing with oil. And it was leaking from the side of the motor on the drivers side behind where the factory lift pump is mounted. I pulled injectors out an found that the number 6 injector body o-ring was busted. I put new o rings on all the injectors an all the tubes. My question is, Where was it leaking from. And how do i fix it, cause now that i fixed all the o rings it still leaks oil slightly. But no sign of fuel mixing in the oil now. No smell or abnormal consistancy in the oil. Thanks guys.
Old Apr 22, 2010 | 04:14 PM
bump
Old Apr 22, 2010 | 08:16 PM
RAW's Avatar
RAW
How about he orings on the fuel bullets/tubes, or the rocker arm cover gasket?
Old Apr 22, 2010 | 10:15 PM
svt28640's Avatar
new tube o rings an valve cover gasket is fine
Old Apr 22, 2010 | 10:24 PM
Whit's Avatar
Site Mascot
check the "T" on the fuel return to tank line, residule flow fron the VP meets up with the line from the head then returns to the fuel cell............see if its leakin there
Dbleo351
Nov 20, 2016 09:34 AM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
ash23k
Dec 30, 2014 08:31 PM
Dec 5, 2014 08:30 AM
