Keep breaking u joints
Old Apr 21, 2010 | 07:25 PM
JSPulliam21's Avatar
Default Keep breaking u joints
A buddy of mine has a 2002 cab and chassis regular cab 4x4, and he is going through u joints about every 1000 miles. The truck i stock height, too. They don't break, but the trunnions wear about halfway through inside the caps. He can't figure it out, and is getting irritated about replacing them. What should we start checking?
Old Apr 21, 2010 | 07:28 PM
Captain Call's Avatar
I would maybe look into balancing the driveshaft.
Old Apr 21, 2010 | 07:59 PM
12vcummins96's Avatar
go spicer non greasables
Old Apr 21, 2010 | 08:14 PM
RAW's Avatar
RAW
I completely disagree with this, I prefer greaseables. But then again, I'm the kind of guy that has the facilities and drive to make sure everything is properly serviced. I agree on the drive shaft balance check. For the speed they turn, they need to be perfectly balanced. 1 ounce at 60 MPH is equal to 7.5 ft. lbs. of force. Doesn't sound like much, but its enough.
Old Apr 22, 2010 | 09:03 PM
I will suggest the balancing. He is buying the Spicer joint.
Captain Call: You don't rent pigs, do you?
Old Apr 22, 2010 | 09:15 PM
casper83's Avatar
you aint talkin about claytons truck are you
Old Apr 23, 2010 | 06:32 PM
Nope. Ben's. Who are you. Send it by PM if necessary
Old May 28, 2010 | 08:52 PM
Turns out the pinion bearings were worn badly causing deflection in the yoke wearing the joints.
Old May 28, 2010 | 09:21 PM
turbo20psi's Avatar
That is a common problem with the torque of these motors over time.Glad u got it fixed.
wildbill
Oct 2, 2015 01:56 AM
maverick52
Recreation Vehicles (RV's)
Aug 25, 2015 10:50 PM
LawdawgSHPD
Aug 21, 2015 06:23 PM
CumminsCoalRoller24/7
Jul 5, 2015 06:30 PM
99RAMS
Tire, Wheel & Suspension
Jan 25, 2015 11:31 PM
