How much hp/mpg will I gain by getting a dual elec. fan setup?
Old Apr 21, 2010 | 07:00 PM
85_305's Avatar
Being Evaluated
Default How much hp/mpg will I gain by getting a dual elec. fan setup?
My fan-clutch is blown on my truck (fan stays on all the time), so instead of repairing that I would like to go the route of dual electric fans. How much hp and mpg can I expect to gain by going this route? It's going to cost money and time to make this change and I want to be sure it's worth it.
Thanks all
Matt
Old Apr 21, 2010 | 07:03 PM
12vcummins96's Avatar
it takes 15hp to turn the clutch fan and mph is all up to how heavy your foot is
Old Apr 21, 2010 | 07:15 PM
tltruckparts's Avatar
https://www.dieselbombers.com/5-9l-r...-write-up.html
theres my writeup for a 1st gen (same install applies for anything) use 1 taurus fan it explains why in the thread.
i noticed no horsepower gain by feel of the seat at least and not much mpg difference, but i got alot better throttle response, faster warm up temps, and steadier temp control when needed
Old Apr 21, 2010 | 07:47 PM
85_305's Avatar
Being Evaluated
15hp eh? Thats a decent amount. I've heard looking thru the forums that 2nd genners see about 2mpg or so w/ the elec fan setup.
I've already scoured it. Thats where I got my idea for the taurus fan from
Old Apr 22, 2010 | 09:54 AM
wes-cummins's Avatar
i did this to my old chevy truck with a 350, and i got about the same results, pretty much just a little throttle response, didnt rly notice more power or better milage,
Old Apr 22, 2010 | 11:50 AM
SSpeeDEMONSS's Avatar
i didnt notice a big difference in either. im just running a single taurus fan right now. ill run 2 when i do the swap.
Garrett
Old Apr 23, 2010 | 11:13 AM
kazairl's Avatar
You'll probably gain as much from fixing your fan clutch as you would by going to electric fans. But taurus fans are cheap.
Old Apr 23, 2010 | 10:54 PM
dshane62's Avatar
i run 2 ele. fans plus left the engine fan on but i did it to keep air moving thru the
a\c condensor now i can sit in traffic and my air stays cold dont warm up like it used to
plus it helps the inercooler work
Old Apr 23, 2010 | 11:03 PM
i can tell you guys honestly that with a cummins, 2 taurus fans are COMPLETELY UNNECESSARY. i tow and get on it hard and it doesnt ever go above 180. only on a hot day sitting it traffic will it climb, and the 1 fan brings it back ck down so quick theres no need for two of them. not to mention you wont be able to make two of them fit. trust me i tried. the radiators are only 31" wide and the fans are 17" fans
Old Apr 24, 2010 | 08:35 PM
85_305's Avatar
Being Evaluated
Really 1 taurus fan was good enough? Somebody told me that they are ok for putting around, but he said that once you start towing taurus fans will overheat very quickly
