Getrag overfill?
Old Apr 21, 2010 | 12:44 PM
MD 91's Avatar
Default Getrag overfill?
simple question for you all i'm sure. I'm wanting to change out gear box fluid and overfill with synchromesh can someone break it down for me? what to look for? anything not to do? what to make sure of? truck has 238k tranny works fine just doing some prevent. maint.
thanks
Old Apr 21, 2010 | 01:12 PM
tltruckparts's Avatar
make sure you drain the oil and refill it by a quart thats about it
your probably going to have to put it in through the top of the shift cover not the side hole, because if you use the side hole, itll pour out before you can overfill it
Old Apr 21, 2010 | 06:51 PM
TTipsword's Avatar
you can use an elbow on the drain plug to make it a higher fill level. also the shifter is a major pain in the a$$. even said it was and well i experienced it toady. if you do so make sure you have a strong buddy to hold that sucker when putting it back in.
Old Apr 21, 2010 | 06:56 PM
12vcummins96's Avatar
why do you want to overfill it thats not good on the tranny
Old Apr 21, 2010 | 07:11 PM
its not bad at all on the tranny. its the best thing you can do to help solve the 5th gear lubrication problems
Old Apr 21, 2010 | 07:16 PM
not what i was taught but maybe you know somthing i dont
Old Apr 21, 2010 | 07:23 PM
seandonato73's Avatar
our trannys seem to be tilted back too far or something like that and it starves some parts of them from getting enough oil.... so you fill them about a quart overfull and that helps to keep everything lubed, thats what i have been told
Old Apr 21, 2010 | 07:35 PM
you are correct for MOST transmissions. the getrag is an exception its just a design flaw by getrag
Old Apr 21, 2010 | 08:15 PM
RSWORDS's Avatar
Its a proven common practice for the getrag. I know its against basic mech principles but its the best way to make them live.
Old Apr 21, 2010 | 08:44 PM
JBradley500's Avatar
i believe its because the transmission was engineered without the thought of the angle it sits in the cummins/dodge trucks. that angle makes it impossible to fill it to the proper level without running out of the fill plug so you can use the PTO top bolt cover to fill it. i had to buy a 3 dollar kerosene pump from rural king, it didnt fit in the hole so i took a lighter to the tip of it and shrunk it down until it fit in the PTO bolt hole. cheap and simple i think. it takes about 10 minutes to do it all if you have everything. i used 5 quarts of 5w-30 synthetic from Mobile1.
wvwelder89
Sep 28, 2014 02:23 AM
