fass 95 pressure an mods
Old Apr 20, 2010 | 08:28 PM
dirt diggler's Avatar
Default fass 95 pressure an mods
well i have a ? whith the truck in my sig. Could i be starving my truck for fuel with the fass 95? smokes heavy down low an at wot i dont even have a light haze an seems to flutter a little . Thanks for eny input my fuel pressure sending unit is bad on the inj pump. i had my pressure checked it was good but the guy that tested it only took it up to 2,000 rpms my truck will run up to 3,700. I also am running a 21cm exaust housing. thanks agian
help
Last edited by dirt diggler; Apr 20, 2010 at 08:28 PM. Reason: Automerged Doublepost
Old Apr 20, 2010 | 08:58 PM
crzycummins's Avatar
well if your getting heavy smoke at first then you have plenty of fuel... that smoke is bc of a load on the motor which will be what you have in the low range but once you get into the higher ranges your load will not be as high bc its not trying as hard. now the flutter you speak of i cant really say. but what you describe in the beginning is common. dont know how old your fass is and it really shouldnt matter but with the mods you have you really shouldnt need much more fuel than what you should have as of now.
Old Apr 20, 2010 | 09:00 PM
RAW's Avatar
RAW
For a proper answer you need to get a fuel pressure gauge in there. We NEED to know how much fuel is getting to the VP. Beg, steal or borrow a fitting, hose and gauge.
Old Apr 20, 2010 | 09:44 PM
Are you running an aftermarker draw straw?
Old Apr 21, 2010 | 01:49 AM
01quadcab's Avatar
you have just the correct amount of fuel for the turbo once lit it's clean. I made 575 with a fass 95 so you have plenty of fuel and held 14psi at wot feeding my tiwns and 200hp ddps
Old Apr 21, 2010 | 03:17 PM
thanks guys. And as for the draw straw im running the stock set up. Shoul i look into something diff ??
Old Apr 21, 2010 | 05:07 PM
The stock pickup tube has been known to cause issues. We can hook ya up with a much better setup.
Old Apr 22, 2010 | 12:24 AM
01quadcab's Avatar
I still run stock pick up no issues the fass draw straws like to leak. if your going that route just sump it.
JoeyMiR
9
Feb 3, 2018 10:05 PM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:55 PM
ramrunner01
9
Jun 4, 2015 03:34 AM
robbyS
Apr 16, 2015 02:22 PM
veggyoilkid
Nov 10, 2014 12:39 PM
