I Think My Airdog Is Going Bad
Old Apr 20, 2010 | 06:23 PM
12vcummins96's Avatar
Question I Think My Airdog Is Going Bad
the fuel pressure is jumping from 20 to 30 psi i have a needle valve before the sending unit my truck has lost power
was boosting 52 psi now cant hit 30psi
i used to peg the pyro now it wont hit 1200
and it wont spin over 2200 i have a 3k kit in it
any opinion is welcome
Old Apr 20, 2010 | 06:28 PM
How long has it been since you changed your filter?
Old Apr 20, 2010 | 06:30 PM
yesterday
Old Apr 20, 2010 | 06:32 PM
How long has it been acting up?
Old Apr 20, 2010 | 06:35 PM
since ennis i called airdog they told me to check connections that its sucking air ive checked all connections all tight
Old Apr 20, 2010 | 06:36 PM
Probably time for a new pump
Old Apr 20, 2010 | 06:38 PM
thats what im thinking
Old Apr 20, 2010 | 07:12 PM
captain_stabbin's Avatar
when my harness comes in, i will drive over to your house an we will put mine on an see what it does, then you can call airdog an tell them ~~
Old Apr 20, 2010 | 07:19 PM
ok
Old Apr 21, 2010 | 07:29 AM
Hammer's Avatar
Why would you have a needle valve in a fuel pressure gauge on an AirDog?.
With an electric fuel system a needle valve is not needed and could be the cause of your gauge jumping around.It may not be a problem with the pump at all just with how you have the gauge installed.You say you just changed a filter and if the gauge line with the needle valve assembly ends up with air in it your turning the pump on could cause it to act like your describing.
I may be out to lunch but a simple filter change to me and there is pressure loss says somethinge else is up.I have seen electric pumps go bad but not aftewr a filter changemunless they were showing signs before the swap.
