Excessive Crank To Start
Old Apr 20, 2010 | 10:49 AM
travisdun's Avatar
Default Excessive Crank To Start
My truck has to crank for a long time before starting.I have tested my glow plug controller it was good and i have changed my glow and they all work. What else would cause this could it be the injectors? Or should i be looking at something else.
Old Apr 20, 2010 | 11:13 AM
12vcummins96's Avatar
possibly a lift pump problem or getting air in the system
Old Apr 20, 2010 | 06:18 PM
2MuchJunk's Avatar
There are a few things that could cause this. Air in the line, Weak injectors, Weak injection pump, Low compression. How fast does the truck crank? If it is just a little slow it may not start. How many miles are on it? After it starts how does it run?
Old Apr 20, 2010 | 08:44 PM
Woody35's Avatar
how much white smoke once it starts up?
Old Apr 21, 2010 | 11:36 AM
travisdun's Avatar
about 260 000kms I have replaced the lift pump a few months back.It cranks over good. It runs good after it starts no issues there.there is a little bit of white smoke when it first starts.I have drained the air out of the system at the t handle and at the filter no change to the starting problem.
Old Apr 21, 2010 | 08:20 PM
2MuchJunk's Avatar
If you rev the engine to 2,000 rpm and hold it there for a little bit then back of the throttle slowly dose it return to idle smoothly or does it drop off sharply?
Old Apr 21, 2010 | 10:40 PM
travisdun's Avatar
When I rev it up and hold it for a bit it will return to an idle smoothly.Is there any way to check the injectors with out removing then?
Old Apr 21, 2010 | 11:06 PM
Woody35's Avatar
no not really. pour some 2 stroke or 30 weight non detergent oil to see if starting improves. make sure timing is advancing. unplug temp sensor on top of engine. computer thinks its -40 out and advances timing all the way.
Old Apr 22, 2010 | 11:32 AM
travisdun's Avatar
Tried disconnecting the sensor did change anything. How much oil should i add?
SkiDooGuy
Sep 9, 2015 05:55 PM
ish1521
Aug 26, 2015 08:42 PM
tmcc14
Apr 21, 2015 03:59 PM
ebg2g
Mar 29, 2015 06:15 PM
musikagod
11
Nov 30, 2014 07:22 AM
