surging under hard load
Old Apr 19, 2010 | 08:53 PM
mainman300's Avatar
Default surging under hard load
Well I was at the dyno this weekend and put down some ok numbers but I have been having a surging issue when I have my edge on 6/5, like im running out of fuel, or I have a timing issue, it runs smooth when I run the edge on 3/5. What I have is in my sig. Just wanted to know if anyone has had these issues with the edge or with jammers?
Old Apr 19, 2010 | 08:56 PM
12vcummins96's Avatar
whats your fuel pressure at
Old Apr 19, 2010 | 09:02 PM
mainman300's Avatar
20 at idle 18 at wot
Old Apr 19, 2010 | 09:10 PM
dirt diggler's Avatar
i have the same prob! but the sending unit for my fuel press is not working. I had it manualy checked. The guy that checked it for me said i was good but he only let me take my truck up to 2000 rpms. Im going to have to find a sending unit. Mine runs fine untill i run it hard on the higher settings??
Old Apr 19, 2010 | 11:53 PM
mainman300's Avatar
I wonder if its my apps
Has anyone had this problem with jammers or the edge? it started when I installed my new used turbo. I could only get 32lbs of boost on the rollers
Last edited by mainman300; Apr 19, 2010 at 11:55 PM. Reason: Automerged Doublepost
Old Apr 20, 2010 | 12:26 AM
My truck does this from time to time. It did it worse with the Adrenaline than it does with the Edge. I believe ive narrowed mine down to my 128K mile VP44.
Old Apr 20, 2010 | 09:44 PM
mainman300's Avatar
Thanks guies for the info! Shoot I was scared it was going to be my vp
Old Apr 20, 2010 | 09:52 PM
Farmboy 2.0's Avatar
ADP Hot Rod VP44!!!!!!
Old Apr 20, 2010 | 09:55 PM
You can make more power with a SO VP44.
Old Apr 20, 2010 | 10:05 PM
Or you can have my ho pump and ill get a new one!!!!
