puting a cummings in a 1 ton gastruck
use the search button. and a gasoline tranny will not hold the power of a cummins, second of all im not sure if itll bolt up it depends on which transmission you have in it now.
and its "cummins" there is no g.
Just do a divorce mount setup then, you can use all the cummmins stuff that way and junk the gasser trans.
And before a lot of people get a bad impression of you I would hurry and stop putting a "G" in cummins.
From what I understood is the earlier dodges had weaker frames and had problems with cracking, so probably have to do some reinforcement on it to handle the Cummins. So that would be a no, I don't think the 85 frame will handle it in stock form.
