wiring question 6.2
Old Apr 17, 2010 | 11:25 PM
gnam's Avatar
Default wiring question 6.2
hello I have put a 84 6.2 in my 89 suburban and got to the wiring part and I'm stumped what will I need to wire to my truck the motor has a harness on it I've got the glow plug figured out and I'll post some pics tomorrow sorry if this is a stupid question
Old Apr 18, 2010 | 12:37 AM
2MuchJunk's Avatar
Was this a gas truck? If so take the hot wire that ran to the distributer to the injection pump and if you have the glow plugs wired up every other sensor should be the same. The only thing I am not sure of is the fast idle I always left it off when converting form gas to diesel and held the throttle open for a minute and called it good.
Old Apr 18, 2010 | 04:09 PM
gnam's Avatar
yes it was a gas truck
Old Jul 31, 2010 | 04:55 PM
latenighthaulers's Avatar
ok im doing the same i have a 90 3500 and wanting to swap a 6.2 into it hard or not? will tranny bolt up? it has a 350 sb in it right now???
Old Jul 31, 2010 | 05:19 PM
2MuchJunk's Avatar
No it's not a hard swap. The trans will bolt up. You will need to put a diesel torque converter in it and you may need to change the governor.
Old Jul 31, 2010 | 05:34 PM
governor?
Old Jul 31, 2010 | 06:25 PM
2MuchJunk's Avatar
Depends which trans it has in it but some of them need the governor changed to change the shift points. If it was me I would just change the torque converter and see how it drives.
Old Jul 31, 2010 | 06:30 PM
i am looking for a 5spd and just change tranny and all not to keen on autos
Old Jul 31, 2010 | 07:21 PM
2MuchJunk's Avatar
The you just need a fly wheel and clutch.
Old Jul 31, 2010 | 09:04 PM
thanks! ill post pics when its done maybe in the next two weeks
cumminspwr11
12
Oct 17, 2021 03:50 AM
Forks diesel nut
Diesel Engine Conversions
Jul 27, 2015 12:19 PM
jedder21
Mar 7, 2015 09:47 PM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
JRB1960
Dec 1, 2014 09:24 PM
