Air Dog Visit - AIR DOG
All fittings should be BRASS!
Old Apr 17, 2010 | 10:11 PM
Weyco Woods Man's Avatar
Default All fittings should be BRASS!
You Make a GREAT! pump guys!! . But all your fittings should be brass. They're not as weak as the ones you're using now!. I had the inlet fitting for the VP44 separate at the first thread. Not while installing it like they caution you about! But when I loose'nd it to re-ajust the angle it was at it came apart!. It shoud'nt have came apart but it did. Got the rest of the fitting out,easy enough without hurting any threads or the v.p.,BUT!!. What do I do now!. Do I get one from you?. Or do I BUY one from someone !!. Input would be helpful!
THANKS, Jeff
Old Apr 17, 2010 | 11:54 PM
12vcummins96's Avatar
wow really good luck
