HOW CAN I TEST MY FAN CLUTCH?
Old Apr 17, 2010 | 09:03 PM
redwood logger's Avatar
Default HOW CAN I TEST MY FAN CLUTCH?
I am wondering if my fan clutch is working properly. Any ideas on how i can test it or find out if it is fully engaging or not. The truck is to loud to hear if it is going on or off while i am driving.
Old Apr 17, 2010 | 09:08 PM
12vcummins96's Avatar
sitting still idling does your temp rise real high or stay normal
Old Apr 17, 2010 | 09:13 PM
tltruckparts's Avatar
shake it forward to back like firewall to radiator. there should be no play in it
Old Apr 17, 2010 | 09:14 PM
sitting idle and driving the temp is fine but as soon as i climb a hill it gets hot. I am going to put in a new thermostat but i wanted to be sure the fan is working right. I think its the thermostat because one time while pulling a long 9% grade with a cord of firewood in the back it was getting hot then all of a sudden the temp dropped to almost normal and i had not finished climbing the hill yet.
Old Apr 17, 2010 | 09:16 PM
pull your thermostat out, its very easy, and drive it. if it stays way cool its your thermostat, if its still getting hot you got a problem somewhere else. and DO NOT buy a thermostat from napa or oreilly or any of those places. a cummins thermostat is a MUST. trust me i learned the hard way
Old Apr 17, 2010 | 09:20 PM
I checked that and there was a very small bit of play but just barely anything.
Ya thanks to this great site i new ahead of time so i got the cummins t-stat for $35 at the local cummins shop instead of paying the local dodge dealer $125 for the one they had.
Last edited by redwood logger; Apr 17, 2010 at 09:20 PM. Reason: Automerged Doublepost
Old Apr 17, 2010 | 09:33 PM
good choice. the other auto parts ones are junk and dont work or fit right most of the time. especially on the first gens, theres a slotted keyway they have to go into and the aftermarket ones dont even have that
Old Apr 17, 2010 | 09:40 PM
wildbill's Avatar
Are you the original owner, or did you buy the truck used??
Old Apr 17, 2010 | 09:43 PM
I bought it used. I sure wish i had got it new then i would know all the history. Its got 220,000 miles now.
Old Apr 17, 2010 | 09:47 PM
wildbill's Avatar
I recommend replacing it the same time as the t-stat. That way your ready for the months ahead (late spring to early fall). Might also be a good idea to have the coolant tested, inspect all the radiator/heater hoses, belt, and the inside of the radiator (corrosion, plugged tubes).
