Off Roading Diesel Discussions of Off Roading , Set Up , Designs , Practices , Techniques , Tips Including Trail Riding , Rock Climbing , Mud Bogging And More
Rockwell axle info
Old Apr 17, 2010 | 08:44 AM
bullrunner777's Avatar
Default Rockwell axle info
I was searching through this forum and found not much info on the oh so famous 2.5 ton axle. I was wondering what the specs are for those, tips and tricks to maintaining them, pictures what do you have them under, if they are legal for street use and stuff like that. Hopefully this can be come a catch all for Rockwell axle info.
Old Apr 17, 2010 | 08:47 AM
FastCR's Avatar
no legal issues of running them on the street, but they suck. they are extremely heavy and it costs a ton of $$$ to get proper brakes on them. Offroad they are cool and they are strong but not recommended for a DD.
Old Apr 18, 2010 | 02:53 PM
Bad93Cummins's Avatar
For street use, gota go with 4 wheel disc conversion, they have anywhere from 6.17-6.67 gears, so you need atlesast a 44" or bigger tire so rpm's aren't threw the roof. Easy to maintain being a militry axle and not alot to them.
Old Apr 26, 2010 | 07:52 PM
Does any body have rockwell's? pics, specs, issues, wreackage? show em if you gotem
Old Apr 26, 2010 | 10:04 PM
chuckstrucks.net go to fourm, everthing you need/want to know about toyota axles all the way up to full blown monter truck plantary axles, etc..
Old Apr 26, 2010 | 10:09 PM
FastCR's Avatar
you could go on pirate4x4 too but lube up your cornhole before you hit the post button.
Old May 18, 2010 | 05:25 PM
01thump's Avatar
with disc brakes they do not weigh much more than a outfitted 1ton axle and are way stronger and cheaper than an built 1ton axle..chucks truck forum check it out all the info you will need hope that helps..
Old May 22, 2010 | 09:06 AM
scarecrow's Avatar
everything you need to know...... Link's to rockwell question's and info... - Pirate4x4.Com Bulletin Board
Old May 25, 2010 | 07:08 PM
so far so good. but again does anyone have them on their truck? What did you use for suspension setup? 4 link and coils, leaf springs, or air spring? remember its not only for me but for anyone thinking about doing this. BTW Overson engineering has tons of stuff for rockwell axles... including new gear ratio sets!
Old Aug 12, 2010 | 09:02 PM
Ragin Cajun's Avatar
Tons of mud trucks run 2.5 tons..they have their ups and downs
Gm's are cheaper but rockwells are stronger
Cummins on the rocks..Lee's 12v
I know a few people with them on the street
as far as gearing takeout rockwells come with 6.72:1
Suspension can be set up leaf sprung or coils it just depends on what you want and how deep your pockets are
Natenelson1
Jan 19, 2015 07:23 PM
Dec 19, 2014 02:30 PM
Dec 3, 2014 08:10 AM
natenel1
Oct 26, 2014 03:09 AM
94cummins12v
Towing and Hauling
Oct 21, 2014 02:50 AM
