How to make more hp from setup?
Old Apr 16, 2010 | 12:30 PM
1st genny nut's Avatar
Default How to make more hp from setup?
im looking to pull around 300 hp outta my gen, what ive done to the truck is already in my sig, i wanna know how far away i am from 300 and what i need to do to get there using no money..... have fun haha thanks for all input
Old Apr 16, 2010 | 12:58 PM
pewder's Avatar
Strap on a bigger turbo, and your going to have to get more fuel in the motor so those stock injectors aren't going to let you get there easily, if at all. Maybe a big air filter as a cold air intake, bigger intake pipe to the turbo.
But there is not much more to do free once you get past the free tune.
Old Apr 16, 2010 | 01:03 PM
aight man so bigger turbo and i already made my cold-air intake thts not in my sig starwheel and smoke screw are maxed out .... do you have ne idea on what kinda hp im pushing right now ?
Old Apr 16, 2010 | 01:17 PM
pewder's Avatar
Do you have a pin in at all? From what everyone claims what they get after a pin and mods I would say getting close to 230 maybe. But ya really cant say cuz each truck varies so much, but lower 200's is around where ya would be.
Here is what i'm judging it off of.
ha ha. Wow he has the same turbo as you have also! So that is basically your truck right there.
Old Apr 16, 2010 | 01:20 PM
ya ive seen this video and no after market fuel pin at all we just turned it to the deepest setting but we have played with the pump some something like 2 turns or so
Old Apr 16, 2010 | 01:26 PM
pewder's Avatar
A fuel pin is only around $105 for a DennyT or M&H. And that will bump ya up on power.
You are running gauges right?
Old Apr 16, 2010 | 01:29 PM
ya as soon as i get my body work and paint job done before june which is round 2000 which btw the parents are doing for me im gonna start working on performance after that so ya the Denny T 2 is in my future so are POD injectors and possible another turn or so on the pump tht should put me where i wanna be
Old Apr 16, 2010 | 01:32 PM
12vcummins96's Avatar
you can advance your timing
Old Apr 16, 2010 | 01:33 PM
maybe invest in some glowshift gauges soon ..... im gonna need em hahaha
ya imma havta look in the 1st gen sticky when i get back from the rod run
Last edited by 1st genny nut; Apr 16, 2010 at 01:33 PM. Reason: Automerged Doublepost
Old Apr 16, 2010 | 01:37 PM
pewder's Avatar
You already need um' need to see what your running with that motor so you can see what else you need so you don't burn a piston. Bigger intercooler to lower egt's will give ya more power. Find a used 2000 Powerstroke intercooler.
http://www.dieseltruckresource.com/d...d.php?t=102027
This has a lot of info too, a little more than our sticky I think.
