Boost PSI runnin Quad Adr
Old Apr 16, 2010 | 08:15 AM
AF1CUMMINS's Avatar
Default Boost PSI runnin Quad Adr
Just curious what kind of boost numbers on the stock turbo you guys are seeing. Even with mine on kill I'm only seeing 22-24 PSI. Just me, but isn't that a little low? Let me know what ya'll think. Thanks.
Old Apr 16, 2010 | 03:58 PM
LawnScum's Avatar
i never ran the quadzilla with my stock turbo, ive ran the smarty and edge juice with it though and was seeing 40+. with just intake an exaust an boost elbow
Old Apr 16, 2010 | 06:44 PM
lobsterman04's Avatar
I was seeing 35+ easy. and once i saw 1800* temp was seen with the torque tune on 10. stock turbo. got lucky
Old Apr 16, 2010 | 10:25 PM
mainman300's Avatar
you need injectors man and you will see more boost
Old Apr 17, 2010 | 12:36 PM
Mark your turbo is wastegated to only produce that amount of boost no matter how much fuel you throw at it. Mine was the same way until I installed a boost elbow. Then it would hit 40+ boost.
Old Apr 17, 2010 | 10:55 PM
Dodgehunter84's Avatar
I agree with luke, a boost elbow is needed
Old Apr 18, 2010 | 06:28 PM
AF1CUMMINS's Avatar
OK, I'm a little green here. What exactly is this boost elbow? And what will it run me? Lucas, drop me a line and let me know somethin bro. Pretty easy to install?
Old Apr 18, 2010 | 07:55 PM
luke46's Avatar
it's what you need I'm putting down about 30lbs now and I'm not real turned up they're around 25 bucks I think plus some shipping it basically blocks off the wastegate I got an adjustable and ended up just blockin it off all the way so you could try that too. it's that little elbow on the bottom of the turbo
Old Apr 18, 2010 | 09:56 PM
Mark I actually might have one here laying around Ill send ya. Let me see if I can find it.
Old Apr 19, 2010 | 10:02 AM
AF1CUMMINS's Avatar
That would be awesome man, thanks!!!! So what's safe a safe psi for a HX35 before you have to start worrying about damaging it? Also, will the higher boost numbers bring down EGTs? I don't really understand how all that works. I figure more air moving fast will, or do I need a bigger turbo to accomplish that?
