dtc codes
Old Apr 16, 2010 | 07:53 AM
swampkilie's Avatar
Default dtc codes
hey guys
did egr delite. got code po306 miss fire on #6 is this a hic up or is there something wrong
Old Apr 16, 2010 | 12:21 PM
riddick01's Avatar
i dont have a delete so idk the full answer to ur question but i know on alot of the later trucks they will 99% of the time throw a code...now what code idk but i know it will throw a code any you just have to get a programmer and write out the code
Old Apr 17, 2010 | 03:28 PM
Mdub707's Avatar
They will throw insufficient EGR flow codes. The EGR delete shouldn't effect your injector performance.
How is the truck running physically? Have you tried clearing the code and driving it more? If you start getting other injectors or different injectors, it could be FICM related too.
Old Apr 17, 2010 | 04:20 PM
swampkilie's Avatar
the truck is running great no miss or bad idle.tried clearing code . comes back as same cyl. also getting [po611 ficm fuel injector control module performace internal ficm failure]
Old Apr 17, 2010 | 07:42 PM
Mdub707's Avatar
Search for FICM test and repair procedure, do that first, it's relatively easy and very inexpensive, that should resolve it. Try that first. I posted the procedure a few times this month already, it's on this board somewhere.
Old Apr 18, 2010 | 10:57 AM
swampkilie's Avatar
hey
have another ques. you gave me two sct comp will they both get rid of the check engine lite and code po401??????
thanks swampkilie
Old Apr 18, 2010 | 08:12 PM
Mdub707's Avatar
They can clear the check engine light yes, but if you have a problem the light will come back. The SCT can eliminate the EGR related check engine light though, but needs to be done with custom tuning (which would be stupid not to get anyways if you're spending the money on an SCT).
Xcal3 holds 3 custom tunes and nothing else
SF3 comes with 3 canned tunes and will also hold 3 custom tunes.
Old Apr 19, 2010 | 07:20 AM
riddick01's Avatar
[QUOTE=Mdub707;540408] The SCT can eliminate the EGR related check engine light though, but needs to be done with custom tuning (which would be stupid not to get anyways if you're spending the money on an SCTQUOTE]
very true...sct is a great tuner but needs some custom work to make it king.
asajay
Sep 10, 2015 12:08 AM
longhorn12
6.7L Performance
Aug 29, 2015 01:28 PM
schwier94
Mar 8, 2015 06:09 PM
KimberlysTruck
Mar 5, 2015 06:28 PM
Altonlee
9
Oct 8, 2014 02:31 PM
