fuel pressure gauge
Old Apr 15, 2010 | 08:50 PM
hulse09's Avatar
Default fuel pressure gauge
i just got a fuel pressuer gauge for my truck its a danin electrical. i have a raptor 150 lift pump on my truck. ok i was looking to hook it up and the port i need to use i replaced witht he 1/2 in fuel line that came with the lift pupm. so i was wondering is there ne place else to hook it up
Old Apr 15, 2010 | 09:16 PM
hotdog_127's Avatar
I just split the fuel line before the injection pump, put a brass tee with barbed fittings on the hose side and put your pressure sending unit in the top...Mine works great
Old Apr 15, 2010 | 09:47 PM
hulse09's Avatar
do u know wht size i will neede of the top your heat so i can go to the hardwaer in the AM and get it
Old Apr 15, 2010 | 10:42 PM
hotdog_127's Avatar
Well whatever size your fuel line is get a brass "t" that size with two barbed fittings. you can get hex bushings to whatever size your sending unit is for the top. Thread it in and clamp your barbed ends with those hoses tight so you don't have leaks and your good to go.
Old Apr 16, 2010 | 07:36 AM
RAW's Avatar
RAW
You could also get a different Banjo fitting for your VP, and install the gauge right there. If you have the tools, you could drill and tap it yourself. Every splice in a hose is one more possibility for a leak down the road.
huntman7
Sep 4, 2015 04:49 AM
ctjkelley
Jun 3, 2015 06:01 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
SMatyac
Jan 24, 2015 10:55 AM
